Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2007
    Feb 2007
    7
    Default Autolisp program to generate grid lines
    Please, I need an Autolisp program to generate grid lines at specified intervals of a defined area (probably, using windows to capture the area) in any AutoCAD version.
    Look forward to receiving your responses.
    Thanks
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Can you use ARRAY for this? You could then define your window and I think the command was EXTRIM to trim all lines outside the boundary...?
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    hatch?
    user defined and double.
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
    Full Member jason tay's Avatar
    AutoCAD 2008
    Jan 2008
    Malaysia
    82
    u may try this vpgrid.lsp
    http://209.85.175.104/search?q=cache...lnk&cd=4&gl=my
    hope can help
  5. #5
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,587
    Here is my 2¢...
    Code:
    (defun c:grd()
    (setvar "cmdecho" 0)
      (setq osm (getvar "osmode"))
    (setvar "osmode" 0)
    (setq p1 (getpoint "\nLower left corner point: ")
          p2 (getcorner p1 "\nOpposite corner: ")
    xd (abs (- (car p2)(car p1)))
    yd (abs (- (cadr p2)(cadr p1)))
    st (getdist "\nStep : ")
    nx (fix (/ xd st))
    ny (fix ( / yd st))
    (if (or (>= st (/ xd 2))(>= st (/ yd 2)))
      (alert "Wrong parameters defined")(exit)(princ)))
      (command "rectang" p1 p2)
      (setq r1 (list (car p1)(+ (cadr p1) st)(caddr p1))
    	r2 (list (car p2)(cadr r1)(caddr p2)))
    (command "pline" r1 r2 "")
    (command "array" "L" "" "R" ny 1 st "")
       (setq c1 (list (+ (car p1)st)(cadr p1)(caddr p1))
    	c2  (list (car c1)(cadr p2)(caddr p2)))
    (command "pline" c1 c2 "")
    (command "array" "L" "" "R" 1 nx st "")
    (setvar "cmdecho" 1)
      (setvar "osmode" osm)
    This one should create simmetric grid:
    Code:
                (defun C:GCL (/)
                (setvar "osmode" 0)
                (prompt "\nPick always first lower left corner point!")
                (setq p1 (getpoint "\nPick first corner point")
                p2 (getcorner p1 "\nPick opposite corner point")
                step (getdist  "\nEnter step : ")
                pc (mapcar (function (lambda (x y)(* (+ x y) 0.5)))
                p1
                p2
                x1 (list (car p1) (/ (+ (cadr p1)(cadr p2) 2)))
                x2 (list (car p2) (/ (+ (cadr p1)(cadr p2) 2)))
                y1 (list (/ (+ (car p1)(car p2) 2))(cadr p1))
                x2 (list (/ (+ (car p1)(car p2) 2))(cadr p2))
                len (abs (distance (list (car p1) (cadr p1))(list (car p2)(cadr
                p1))))
                wid (abs (distance (list (car p1) (cadr p1))(list (car p1)(cadr
                p2))))
                deltax (rem len step)
                deltay (rem wid step)
                xcount (fix (/ len step))
                ycount (fix (/ wid step)))
                (if (zerop deltax)(progn (setq oddx t)(setq oddx nil)))
                (if (zerop deltay)(progn (setq oddy t) (setq oddy nil)))
                (if (or (and (> (car p2)(car p1))
                (< (cadr p2)(cadr p1)))
                (and (< (car p2)(car p1))
                (< (cadr p2)(cadr p1))))
                (setq way t)(setq way nil)))
                (if way
                (setq ll (list (car p1)(cadr p2))
                ul p1
                ur (list (car p2)(cadr p1))
                lr p2))
                (setq ll p1
                ul (list (car p1)(cadr p2))
                ur p2
                lr (list (car p2)(cadr p1)))))
                (if oddy
                (command "line" ll lr "")
                (command "-array" (entlast) "" "R" ycount 1 step))
                (progn (command "line" ll lr "")
                (command "copy" (entlast) "" ll (list (car ll)(+ ( cadr ll)(/ deltay
                2))))
                (command "-array" (entlast) "" "R" (1+ ycount) 1 step)
                2))))))
                (if oddx
                (command "line" ll ul "")
                (command "-array" (entlast) "" "R" 1 xcount step))
                (progn (command "line" ll ul "")
                (command "copy" (entlast) "" ll (list (+ (car ll)(/ deltax 2))( cadr
                ll)))
                (command "-array" (entlast) "" "R" 1 (1+ xcount) step)
                ll)))))
                (prompt "\n\t\t***\tType GCL to execute \t***\n")
    ~'J'~
    Last edited by fixo; 25th Mar 2008 at 09:36 pm. Reason: in addition to first routine
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
  6. #6
    Senior Member
    not specified
    Feb 2006
    243
    here is my lisp
    Code:
    (defun c:mknet (/ p1 p2 l w nx ny p3 p4 i k)
      (command "._undo" "_BE")
    (setq obm (getvar "blipmode"))
    (setq osmd (getvar "osmode"))
    (setq andr(getvar"angdir"))
    (setvar "angdir"1)
    (setq andb(getvar"angbase"))
    (setvar "angbase"(/ pi 2))
    (setq aunt(getvar"aunits"))
    (setvar "aunits"2)
    (setvar "dimaunit"2)
    (setvar"dimadec"4)
    (setq clyr(getvar"clayer"))
      (setq d (getdist "\n enter length of square: "))
      (setvar"snapmode"1)
      (setvar"snapbase"(list 0 0))
      (setvar"snapunit"(list d d))
      (setvar"osmode"0)
      (setq p1 (getpoint "\n enter upper left corner"))
      (setvar"snapbase"(list(car p1)(cadr p1)))
      (setq p2 (getcorner p1"\n enter other corner"))
      (setq lyr(strcat"net"(rtos d 2 0)"0"))
    (setq l (abs(-(car p2)(car p1))))
    (setq w (abs(-(cadr p1)(cadr p2))))
    (setq nx (/ l d))
    (setq ny (/ w d))
    (setq nx1 (fix nx))
    (setq ny1 (fix ny))
    (setq p3 (list (car p1)(cadr p2)))
    (setq p4 (list(car p2)(cadr p1)))
    (setq p5 (list(+(car p1)(* nx1 d))(cadr p1)))
    (setq p6 (list(car p1)(-(cadr p1)(* ny1 d))))
    (setq sfa (* 0.025 d))
    (command "layer" "m" lyr "c" "54" "" "L" "continuous" "" "LW" 0.15 "" "")
    (command "layer" "m" "nettxt" "c" "white" "" "L" "continuous" "" "LW" 0.20 "" "")
    (setq i 0)
    (while(<= i nx1)
      (setvar "osmode"0)
      (command"layer" "s" lyr "")
      (command"color" "bylayer")
      (command "line" (list(+(car p1)(* i d))(cadr p1))(list(+(car p1)(* i d))(cadr p6)) "")
      (setq pnx (list(+(car p1)(* i d))(cadr p1)))
      (setq pnx1 (list(+(car pnx)(* 0.01 d))(-(cadr pnx)(* 0.01 d))))
      (command"layer" "s" "nettxt" "")
      (command "text" pnx1 sfa 200 (strcat"X="(rtos(car pnx)2 0)))
      (setq i (+ 1 i))
    (setq k 0)
    (while(<= k ny1)
      (command "line" (list(car p1)(-(cadr p1)(* k d)))(list(car p5)(-(cadr p5)(* k d)))"")
      (setq pny (list(car p1)(-(cadr p1)(* k d))))
      (setq pny1 (list(+(car pny)(* 0.01 d))(+(cadr pny)(* 0.01 d))))
      (command "text" pny1 sfa 100 (strcat"Y="(rtos(cadr pny)2 0)))
      (setq k (+ 1 k))
      (command "._undo" "_END")
      (setvar"clayer"clyr)
      (setvar"angbase"andb)
      (setvar "angdir"andr)
      (setvar"aunits"aunt)
      (setvar"snapmode"0)
      (setvar "osmode"osmd)
  1. Grid lines displayed instead of Grid Dots
    By aka_norm in forum AutoCAD Beginners' Area
    Last Post: 25th Jun 2007, 08:08 am
  2. Autolisp program
    By george in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Feb 2007, 08:35 pm
  3. Creating a new layer in an autolisp program
    By Kirk in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Nov 2006, 03:29 pm
  4. Show grid Lines??
    By puzzled in forum AutoCAD General
    Last Post: 17th Jul 2006, 03:57 pm
  5. Merging lines drawn by AutoLISP as an object, Possible?
    By moss8299 in forum AutoCAD Drawing Management & Output
    Last Post: 29th Nov 2005, 07:05 am
