Results 1 to 10 of 10
    Full Member Matho's Avatar
    AutoCAD 2008
    Oct 2007
    Australia - Fremantle
    25
    Default Aligning text around a circle/arc
    Hi all
    How do I make text flow around a circle/arc? I know there is a command but i'm not having much luck finding it.
    Thanks once again
    Refer Eg.
    AutoCAD 2008
    Oct 2007
    25
    Found it in express tools. It's all good now
    Express>Text>Arc-Aligned Text
    Super Member
    MisterJingles's Computer Details
    Windows 10 Pro 64bit
    Intel Core i7
    4.00GHz
    32GB
    GeForce GTX970
    Mechanical 2016
    Apr 2009
    South Africa
    533
    I dont see this on Autocad 2007 LT. Is there a different command for this function here?
    Junior Member
    AutoCAD 2006
    Jan 2008
    22
    in 2008 it works fine
    it here :
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    LT does not have Express Tools and, more importantly, without an add-on program such as AutoCAD LT Toolbox, it does not have the ability to use Lisp routines. But all is not lost. Here are two suggestions.
    Over in the AutoDesk Discussion Groups frequent contributor Dean Saadallah offered this suggestion. "DIVIDE or MEASURE command, use a block consisting of a letters, explode and edit afterwards." It is by no means an elegant fix but it would do in a pinch.
    The other answer might be found by searching for a Diesel routine written by Robert Freeman for AutoCAD LT called Text on Arc. I have no direct experience with the loading of Diesel routines nor with this particular routine but I recommend you research it a little further and determine whether or not it will suit your needs.
  6. #6
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    LT doesn't have Express Tools; Arc Aligned Text.
    Like Dean, and ReMark quoted, "Explode and edit (rotate), as required."
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  7. #7
    Junior Member
    AutoCAD 2006
    Jan 2008
    22
    Hello all here goes the 2nd part iu have the drawing all doen , but i see that the to arcs an boths sides look wrong,, how do i fix it so they look similiar or porportion to the center ones,-
  8. #8
    Junior Member
    AutoCAD 2006
    Jan 2008
    22
    Hello all here goes the 2nd part i have the drawing all done , but i see that the to arcs an boths sides look wrong,, how do i fix it so they look similar or proportion to the center ones,-
    http://i155.photobucket.com/albums/s298/macussa/fgh.jpg
  9. #9
    Junior Member
    AutoCAD 2006
    Jan 2008
    22
    here its in .dwg
  10. #10
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    your more likely to get your second part answered if you start a new thread
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  1. Circle Text
    By CADgirl in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2007, 10:35 pm
  2. Aligning text to 0 on Z plane
    By notmilk in forum AutoCAD General
    Last Post: 6th Mar 2007, 12:37 am
  3. Circle Text
    By Perto in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2006, 05:14 pm
  4. Aligning text. I didn't clarify my question below.
    By JUJJ in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2005, 06:17 am
  5. Text around a circle
    By Tara in forum AutoCAD General
    Last Post: 17th Oct 2003, 04:59 pm
