Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    Default pavement jointing lisp
    i know this would be cheating but it would save a lot of time
    anyone know of a pavement jointing lisp that would create a jointing layout for a given closed polyline - with specified minimum and max lengths and area ratios.
    And would never create acute angles.
    Reckon this could be done??
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    You would need to pick horizontal and vertical control lines then corresponding limits.
    You can then easily put rules in place divide max joint length into total length or fixed width with reminder.
    If object outside is polyline you over extend you joint lines then use trim with a fence. Secret is fence is another poly line offset from original poly line.
    Super Member
    AutoCAD not applicable
    Jul 2007
    639
    Here is a start.. for you to play with...
    It divdies a control line and copies a line (joint) in one direction..
    I guess you could add the polyline trim..as per BIGAL's suggestion.
    BTW I think this was CarlB's routine , I just added the approx centres bit..
    Code:
    (defun c:place ()
      (setvar "cmdecho" 0)
      (setq PtList nil SegTot 0 Oflag T)
      (princ "\nSelect object(s) to distribute:")
      (setq ss (ssget))
      (initget 1)
      (setq ptbase (getpoint "\nSelect base point of objects: "))
      (setq Pt1 (getpoint "\nSelect starting point <use object>: "))
      (if (not Pt1) (setq Pt1 PtBase Oflag nil))
      (initget 1)
      (setq Pt2 (getpoint Pt1 "\nPick point for last object: "))
      (initget 1)
      (setq TDist (distance Pt1 Pt2))
      (setq TAng (angle Pt1 Pt2))
      (setq Numdiv1 (getreal "\nEnter approx divide centres :"));---USER ENTERS APPOX CENTRES, SET TO `NumDiv1'
      (setq dn1 (/ TDist Numdiv1))  ;-----------------------DIVIDES DISTANCE BY CENTRES, SET TO `DN1'
      (setq NumDiv (fix (+ dn1 0.5))) ;--------------------FIXS `DN1' TO NEAREST REAL NUMBER
      (setq Seg (/ TDist NumDiv))
      (if Oflag (setq PtList (cons Pt1 PtList)))
      (repeat NumDiv
        (setq SegTot (+ SegTot Seg))
        (setq Pt (polar Pt1 Tang SegTot))
        (setq PtList (cons Pt PtList))
      (setq PtList (reverse PtList))
      (foreach x PtList
          (command "._copy" ss "" Ptbase x)
      (setvar "cmdecho" 1)
    If at first you don't succeed, then maybe failure is more your style.
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    thanks guys
    I like the place lisp by the way
    I 'll have a look further into it and repost what i come up with.
    Thanks
  5. #5
    Full Member
    AutoCAD 2008
    Feb 2008
    53
    I have been trying to do this too. I found a lisp that distributes blocks along a polyline, but cant get it to rotate the blocks along with the line. They stay oriented the same way.
    I am trying to create a path, two tiles wide, along a polyline..
  6. #6
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    post lisp so we can have a look
  7. #7
    Super Member
    Jul 2007
    639
    No need to use lisp, the MEASURe command does exactly what you are trying to do.
  8. #8
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    i know - i just wanted to see what he was using instead
  9. #9
    Super Member
    Jul 2007
    639
    Sorry russell, my comments were directed to steniz, not you.
  10. #10
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    Nah its cool - so on a different note - mate where did the origin pic go. haha
  1. problem, trying to running a list of lisp from within a lisp
    By twind2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2007, 04:27 pm
  2. calling another lisp from within my lisp
    By thalon in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Feb 2006, 09:56 pm
  3. siding, roof tile, pavement tile images ??
    By lepusha in forum Blocks, Images, Models & Materials
    Last Post: 26th Feb 2004, 01:13 am
