Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: Trim Solids
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    Default Trim Solids
    I am having trouble trimming 2 solids to the same surface in Autocad 14. What is the best method to trim or create the image in the attached DWG. I need to be able to have the center of the tube section hollow and protrude through the top and bottom flange.
    This is a weldment that I need to make. It allows product to pass through the center.
    Please see attachment.
    I tried to upload a GIF but had an error doing so.
    Thanks.
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Maybe use the subtract command to remove the cylinder area from the plates?
    Or does that remove the cylinder too? If you did the outside of the cylinder first and then the inside you could use subtract and it would remove the area of the interior of cylinder as well as the plates.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    Yes it does remove the cylinder also. It will leave only the portion of the cylinder that intersects with the plates. I've tried using slice and that worked to a degree, but the square plate showed a solid face when shading.
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    I was able to do it by sweeping a circle of the same diameter as the inside of the tube, but 1 - I don't think R14 has the sweep command, and 2 - subtracting it makes it all one entity. Not sure if that's what you want.
    flickr |
    work | blog | creed
  5. #5
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    You will need to subtract a solid cylinder, the same diameter as the tube, from the plates to make a hole for the tube.
  6. #6
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    That's what I was thinking. And if you want the parts to remain separate you'll have to subract said cylinder from the plates and then again from the original cylinder as it appears to have a solid area in the middle.
    ^ disregard. I just double checked and it doesn't have a solid area...
    flickr |
    work | blog | creed
  7. #7
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    I will try that SLW210.
    Rustysilo I don't know that r-14 has a sweep command, but thanks.
  8. #8
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    No sweep in r14.
    This what you after? I made 2 cylinders 1 on top of the other and subtracted individually.
  9. #9
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    Yes but the section of cylinder sticking out above the plate needs to be trimmed off flush.
    By the way how did you create the image you posted
  10. #10
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    SLW, how did you draw the cylinder? Is there a quick way to draw it exactly where it needs to be or do you have to draw it and then move/rotate into place?
    flickr |
    work | blog | creed
  1. 3d: To Trim Or Not To Trim...
    By lifeaudio in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Aug 2007, 05:34 pm
  2. 3d trim
    By Arash in forum AutoCAD General
    Last Post: 31st Jul 2007, 06:25 am
  3. Trim in 3D
    By alijahed in forum AutoCAD General
    Last Post: 6th Jul 2007, 05:53 am
  4. Trim in 3d
    By cullyr in forum AutoCAD General
    Last Post: 15th Dec 2006, 12:24 am
  5. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
