Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
Thread: Trim Solids
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    To remove the extra pipe, you can just make a cube larger than the pipe and flush with the plate and subtract or taper faces or slice. I just rotated the cylinder using the reference option, once I lined it up with the tube. In 2008 you can just sweep up a centerline, though.
    I do screen grabs with snag-it, you can use Printscreen and paint. Save as .jpg.
  2. #12
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    I noticed when creating the cylinder you have the option for axis endpoint which lets you place it wherever you want. Very cool. I was able to draw it right where it needed to be by snapping to the centers of the endpoints.
    Tip: If you use Alt-Print Screen it will only grab the active window as opposed to the entire screen.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  3. #13
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    Thanks, You guys are awesome. I learned a lot today with your help. Yall made it look easy
  4. #14
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    Sure. SLW is pretty good with this stuff.
    If you have the funds I recommend upgrading to '08. Well I guess '09 now. It has new 3d features like sweep and loft which can come in handy I'm sure.
    flickr |
    work | blog | creed
  5. #15
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    Southeastern USA
    6
    I will look into the latest version. thanks
  6. #16
    Full Member Cadfused's Avatar
    Cadfused's Computer Details
    Windows XP Professional SP3
    Dell Precision M90 laptop
    Intel Core duo dual core
    2 gb SDRAM
    nvidia quadro fx1500m and 250 mb
    149 gb
    3ds Max 2010
    Jan 2008
    7 minutes from Hershey (Land of Chocolate) & 12 minutes from Harrisburg (Pennsylvania State Capitol)
    57
    Though a day late and a dollar short....what i typically do is just make a copy of the tube and move it, say, 12 units away and then use the subtract command to make the cut into the plate for the tube, itself. After that, i just move the copied tube 12 units back into place replacing the subtracted one. if the idea is to have the tube flush with the face of plate, from there i would use the slice command and pick three points on the surface of the plate to cut the tube flush with the plate. for now, that may help you in release 14.
  7. #17
    Forum Newbie
    DryDiver's Computer Details
    Microsoft Windows 7
    (2) FFD1975W
    Facilities Mgmt
    DryDiver's Discipline Details
    Designer-Facilities management
    Facilities Mgmt
    AutoCAD 2012
    Sep 2012
    Western Kentucky
    3
    DECK LAY-OUT-B.dwgI am having a very hard time as I am unable to trim the "boards" in my drawing. I have atteched the drawing which shows all are solids but still I cannot perform this operation?
  8. #18
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    What boards (decking) are you trying to trim back?
    Is this residence or a commercial building?
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    Which boards are you trying to trim and "to what" are you trimming?
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    I think he is trying to miter the boards at each corner. Perhaps SLICE using the Surface option would be one way to attack the problem.
  1. 3d: To Trim Or Not To Trim...
    By lifeaudio in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Aug 2007, 05:34 pm
  2. 3d trim
    By Arash in forum AutoCAD General
    Last Post: 31st Jul 2007, 06:25 am
  3. Trim in 3D
    By alijahed in forum AutoCAD General
    Last Post: 6th Jul 2007, 05:53 am
  4. Trim in 3d
    By cullyr in forum AutoCAD General
    Last Post: 15th Dec 2006, 12:24 am
  5. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
