Code:
(defun extract-nums (str /
                         ; local functions
                         is-num is-char parselst
                         ; local variables
                         cntr x str_lst new_lst lst_of_lst final_lst
  ;;; FUNCTION
  ;;; returns a list of reals from a given string
  ;;; function does _not_ check argument type
  ;;; example; given the string "one 12 two 22.3 three .55 four 2.255"
  ;;; the function would return (12.0 22.3 0.55 2.255)
  ;;; ARGUMENTS
  ;;; str = string
  ;;; USAGE
  ;;; (setq lst_of_reals (extract-nums "str"))
  ;;; PLATFORMS
  ;;; 2000+
  ;;; AUTHOR
  ;;; Copyright 2004 Mark S. Thomas
  ;;; mark_at_theswamp.org
  ;;; VERSION
  ;;; 1.0
  ;; returns T if 'n' falls between 48 and 57
  ;; ascii characters 0-9
  (defun is-num (n)
    &#40;and &#40;> n 47&#41; &#40;< n 58&#41;&#41;
    &#41;
  ;; returns T if 'n' is _not_ between 48 and 57 or 46
  ;; all ascii characters other than 0-9 and '.'&#40;dot/period&#41;
  &#40;defun is-char &#40;n&#41;
    &#40;not &#40;or &#40;and &#40;> n 47&#41;&#40;< n 58&#41;&#41; &#40;= n 46&#41;&#41;&#41;
    &#41;
  ;; Stig Madsen
  ;; returns a list of lists delimited by 'delim'
  ;; example
  ;; given the list '&#40;12 0 32 56 0 45&#41; where '0' is the delimiter
  ;; &#40;parselst 0 '&#40;12 0 32 56 0 45&#41;&#41;
  ;; return would be &#40;&#40;12&#41;&#40;32 56&#41;&#40;45&#41;&#41;
  &#40;defun parselst &#40;delim lst / l ll&#41;
    &#40;while lst
           &#40;cond
             &#40;&#40;not &#40;eq &#40;car lst&#41; delim&#41;&#41;
              &#40;setq l &#40;cons &#40;car lst&#41; l&#41;&#41;
              &#41;
             &#40;&#40;setq ll &#40;if l &#40;cons &#40;reverse l&#41; ll&#41; ll&#41; l  nil&#41;
              &#41;
             &#41;
           &#40;setq lst &#40;cdr lst&#41;&#41;
           &#41;
    &#40;reverse &#40;if l &#40;cons &#40;reverse l&#41; ll&#41; ll&#41;&#41;
    &#41;
  ;; ================== main starts here =======================
  &#40;setq str_lst &#40;vl-string->list str&#41;
        cntr 0
        &#41;
  &#40;while &#40;setq x &#40;nth cntr str_lst&#41;&#41;
         &#40;cond
           &#40;&#40;= x 46&#41; ; <dot>
            &#40;if &#40;is-num &#40;nth &#40;1+ cntr&#41; str_lst&#41;&#41;; next n is a num
              &#40;setq new_lst &#40;cons x new_lst&#41;&#41;
              &#41;
            &#41;
           &#40;&#40;is-num x&#41;
            &#40;if &#40;is-char &#40;nth &#40;1+ cntr&#41; str_lst&#41;&#41;; next n is not a num
              &#40;setq new_lst &#40;cons 32 new_lst&#41;&#41;
              &#41;
            &#41;
           &#40;&#40;= x 32&#41; ; <space>
              &#41;
            &#41;
           &#40;&#40;= x 80&#41; ;
              &#41;
            &#41;
           &#41;; cond
         &#40;setq cntr &#40;1+ cntr&#41;&#41;
         &#41;; while
  &#40;if new_lst
    &#40;progn
      &#40;setq lst_of_lst &#40;parselst 32 &#40;reverse new_lst&#41;&#41;
            final_lst &#40;mapcar 'atof &#40;mapcar 'vl-list->string lst_of_lst&#41;&#41;
            &#41;
      &#41;
    &#41;
  &#41;
;; test function
  &#40;defun c&#58;e2sl &#40;/ ent txt&#41;
    &#40;if &#40;setq ent &#40;car &#40;entsel "\nSelect text&#58; "&#41;&#41;&#41;
      &#40;if &#40;setq txt &#40;cdr &#40;assoc 1 &#40;entget ent&#41;&#41;&#41;&#41;
        &#40;extract-nums txt&#41;
        &#41;
      &#41;
    &#41;
