Results 1 to 5 of 5
Thread: Transform?
    Full Member
    AutoCAD 2008
    Nov 2007
    SoCal
    46
    Default Transform?
    Hi guys,
    In MAP, i used to be able to use a command under the MAP menu pull down command to rotate, scale, stretch an image with that one command. Maybe is was an image transform command, i just can't remember the exact command.
    Anywho, now i am w/o MAP, is there such a command with ACAD 2008?
    TIA
    Full Member beauXjames's Avatar
    AutoCAD 2008
    Apr 2008
    Austin, TX
    56
    not that I know of, but you've also got to realize that your objects aren't as 'smart' as objects in something like MAP...what I'd do, is make your object into a block, then when you insert the block, you can set values for scaling and rotation...of course, if you want to stretch, then just don't constrain your scale...
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Is rubbersheet available in normal AutoCAD? If transform is not then that would be another viable option IF available.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    The Align command might do what you want.
  5. #5
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    YuhHay! I didn't know about that one lps. Very cool. In C3D we have all three options! Woohoo!
    flickr |
    work | blog | creed
  1. transform a Spline in a polyline.....
    By mfalcaof in forum AutoCAD General
    Last Post: 12th Jul 2006, 12:38 am
