Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: e-transmit
    Forum Newbie
    AutoCAD 2002
    Apr 2008
    9
    Default e-transmit
    Hello guys,
    Is there a way where in I could e-transmit all dwg files in one go and would result to individual zip file?
    Senior Member azzro10's Avatar
    azzro10's Computer Details
    XP Pro
    AutoCAD 2010
    Dec 2007
    Melbourne, Australia
    311
    im pretty sure u'll have to do them seperatly mate, u can only modify the file structure within the zip file, not create individual zip files.
    You can get it jumpin' You can get it pumpin' You can get it chasing a cow. Matter o' fact, I got it now.
    Forum Newbie
    AutoCAD 2002
    Apr 2008
    9
    thanks mate..maybe I have to learn to be persistent.
    see ya
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    It is possible with a short trick.
    Save the fallowing lisp file on your computer. Open AutoCAD, go to Tools>Load applications, locate the lisp and drag it in the startup suit. Close the window and go to File>Open. Select all the files you wish to process (use the CTRL and Shift keys for multiple selections) and press Open. The program should do the rest of the work.
    Remove the file from the startup suit!!!
    Code:
    (defun etra()
      (command "qsave")
      (command "-etransmit" "c"
           (strcat (getvar "dwgprefix")
               (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 3))
               "ZIP")
    (etra)
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  5. #5
    Forum Newbie
    AutoCAD 2002
    Apr 2008
    9
    thanks fuccaro,
    I did what you said.
    I tried it but it only created .txt files not the zip files. And besides it only happen when you close the application (autocad) itself.
  6. #6
    AutoCAD 2006
    Nov 2002
    3,540
    It could be a problem with command parameters changed since 2002.
    Try to make an Etransmit using the keybord only (not clicking with the mouse). If it can be done, the Lisp can be changed accordingly.
    Enter in the command line _etransmit<enter> (see the underscore!). Follow the prompts. If it works as expected, press F2 to see the command line, copy and paste here the relevant lines. If AutoCAD 2006 works different as 2002, I will change the lisp.
    If _etransmit opens the dialog box, try with -etransmit (replace the underccore with dash)
  7. #7
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    one thing about that lisp, do you need to set filedia to 0 at the beginning, and then back to 1 at the end ?
    otherwise a dialogue box appears
  8. #8
    Forum Newbie
    AutoCAD 2002
    Apr 2008
    9
    I got it.
    Thanks a lot. This will surely help me save time..
    Hope to learn from you more.
    See ya.
  9. #9
    Forum Newbie
    AutoCAD 2002
    Apr 2008
    9
    fuccaro.
    Thanks a lot. Your code is very useful..
    see ya again.
  10. #10
    AutoCAD 2006
    Nov 2002
    3,540
    Glad to help! What was the problem?
  1. E Transmit Error
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2008, 02:01 pm
  2. E Transmit
    Last Post: 1st Jun 2007, 02:31 pm
  3. E-Transmit and X-Clip
    By brownpj in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2005, 07:28 pm
