Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Senior Member dusko's Avatar
    AutoCAD 2010
    Dec 2007
    Croatia - the land of grape and honey
    212
    Default to put objects on z=0
    hello!
    i have drawing where blocks z coordinate have value.
    how can i select all and set z coordinate to 0?
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Look into the flatten command. This is an express tool.
    Alternatively, select all, open the properties palette and at the top drop it to block references, and then in Z set 0
    Can talk you through more if you need any more help with this.
    AutoCAD 2010
    Dec 2007
    212
    nothing!
    check it out, use 3d orbit.
    (i have about 100 similar blocks in one drawing)
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    Are the blocks inserted on a Z-height? Or is the block drawn on a Z-height?
    MTJIGSTRING = BAZINGA
  5. #5
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Use the block editor to update the block and put all on 0.
  6. #6
    AutoCAD 2010
    Dec 2007
    212
    Quote Originally Posted by Tiger View Post
    i think inserted (not mine work).
  7. #7
    AutoCAD 2010
    Dec 2007
    212
    Quote Originally Posted by LCE View Post
    as i see blocks are drawn in z=0.
    (you can check it out in attachment in previous post)
  8. #8
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Best bet would be to explode it, set all entities to Z=0 or Elevation=0, then recreate the block.
  9. #9
    AutoCAD 2010
    Dec 2007
    212
    i have about 100 blocks...no cure for this?
  10. #10
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    not 100 of the same block then?
  1. AEC Objects
    By mshearer in forum AutoCAD General
    Last Post: 17th Jun 2010, 05:36 pm
  2. Objects
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2008, 02:11 pm
  3. Displaying 3D objects as 2D objects?
    By spittle in forum AutoCAD Drawing Management & Output
    Last Post: 28th Aug 2007, 05:10 pm
  4. Selecting objects that are hidden by other objects
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 17th Jul 2007, 07:57 am
  5. Asking help for 3d objects
    By hamid85 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Nov 2006, 12:26 pm
