Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    4
    Default How To Make A 3d Shell Out Of A 3d-solid
    I have done the attached 3D solid CAN with help of extrudes, regions, unions, subtracts, rotation and other various 2D & 3D commands. but i cannot make a shell out of it with a wall thickness 3mm. I do not get any error message as well. Please give me a guidance. Thanks.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    Moved to 3D Modeling section.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    4
    I am in 3D Modeling. You mean to draw the whole object again? my problem the "shell" doesnt work for this solid object what I have done already. (Normally it had worked with other objects what I have tried with)
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    4
    i tried to isolate certain parts thru slicing and certain parts I get the shell through but not with all the parts. Tried with several sections but unable to identyfy a possible reason why the shell doesnt work for the whole object.
  5. #5
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,433
    What I meant was, I moved your question to the 3D section so the right people will see it. I don't use Autocad for 3D, but when I tried to shell your object, I got this message: "Non-planar faces cannot be extruded and are ignored for this operation."
  6. #6
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    4
    thanks i will look into it.
  7. #7
    Full Member
    AutoCAD 2007
    Sep 2006
    31
    pretty sure this is down to solid complexity.
  8. #8
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    i would agree with Paulhea its most likely down to the complexity of the object the shell command is very tempremental and if you try shell some thing that produces self intersections it will fail. i think it is prob this that is stopping it, something is self intersecting after the shell and the program cannot fill in the missing data itself. i suggest you slice and dice the model shell what you can the re-draw the parts that will not withour all the blend radii and fillets, the try again. you could try scaling a copt of the model slightly smaller and subtracting but this will only work so far.
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Your minimum radius of curvature is less than 3mm. I think I would use a real 3D modeling program for something like this.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  10. #10
    Full Member
    AutoCAD 2007
    Sep 2006
    31
    Quote Originally Posted by JD Mather View Post
    How did you get to that JD? Is it the original .dwg file imported into inventor?
    I tried that but still couldn't shell it.
  1. How to make a 3D solid transparent looking in AutoCAD 2005?
    By Alan123 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Apr 2010, 05:41 pm
  2. make model into solid
    By deangelis in forum SolidWorks
    Last Post: 7th Dec 2007, 03:46 pm
  3. How do I make this into a solid?
    By p2bc in forum AutoCAD General
    Last Post: 30th Aug 2005, 03:39 am
  4. How to add texture or make solid?
    By Vaker in forum AutoCAD General
    Last Post: 13th Dec 2004, 02:36 pm
  5. Make a few line objects into 3d solid?
    By DREWDIN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Dec 2004, 09:10 pm
