Results 1 to 8 of 8
    cadet
    Default Alpha Channel Transparency?
    When inserting a raster image into a DWG drawing, does AutoCAD support Alpha Channel Transparency? (AutoCAD 2004)
    I’m trying to add an effect to a small portion of a drawing using Photoshop. I printed the AutoCAD drawing to a raster file format (png), opened the file in Photoshop, deleted everything except the portion I wanted to modify, saved the work on a transparent background, and then inserted the transparent image back into my AutoCAD drawing on paper space above an underlying model. I kept the pixel size the same as the drawing size to maintain registration (at 600 dpi).
    I was expecting the underlying AutoCAD drawing to show through the transparent part of the overlaying raster image in paper space, but the overlying raster image completely blocks everything underneath.
    Neil Hardy
    You can use the draw order command.
    Type dr on the command line ( this is shortfor Draw Order)
    You are then asked to select a component e.g. line, block, or in this case an image...so...select the raster image you have inserted...press return
    It then asks you where in the draw order it should go, in front of another object, behind another object, generally to the front or generally to the back, in this case by hitting return you choose the default which is 'generally to the back' .
    So to summarise,
    type dr ...hit enter
    select image...hit enter
    hit enter again
    hey presto the CAD line work now shows over the image.
    Regards
    Neil
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    AutoCAD has very limited transparency support (it does not support alpha transparency). See here for details.
    An alternative method would be to plot your drawing (minus images) to EPS (see here) . Import the drawing to Photoshop (see here) and then add the images as layers working with alpha transparenct, opacity etc. as required.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    cadet
    Default Thank You
    Thanks for the input. Apparently, I need to dig in and learn some channel basics. I just recently discovered the alpha channel (whatever that is) carries the transparency properties. It looks like AutoCAD supports “bi-tonal” transparency. I don’t know what the difference between bi-tonal and alpha channel transparency is, but I can speculate. I was able to set the AutoCAD properties on an imported black & white image to enable transparency, but haven ‘t tried it on a shaded image.
    I’m somewhat new to Photoshop. Coming from a Windows background and AutoCAD graphics, learning Photoshop is overwhelming, frustrating and not intuitive. The help sections for Photoshop typically reference numerous items without a method to tunnel into the references, so it’s like reading Greek.
    I’ll do some more reading on channels and continue hacking away. I’ll need to abort my current hopes of polishing a particular AutoCAD image because I ran out of time and had to make delivery, but will try again on future projects.
  5. #5
    Senior Member
    not specified
    Aug 2003
    Richmond, Va.
    150
    Try Modify > Object > Image > Adjust. Select the image, and in ACAD 2005 it brings up an Image Adjust dialog box with sliders for Brightness, Contrast, and Fade. I used this to fade a multi-colored screenshot image so my lines (on another layer) would stand out.
  6. #6
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Just note that "Fade" is not the same as opacity. The images fades to the background colour but underlying linework will not be seen.
    The truth is that AutoCAD image support is just not very good - something for the wish list I think.
  7. #7
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    Winston-Salem, NC - USA
    4,447
    Quote Originally Posted by CADTutor
    Maybe on the next release . How long did it take to get gradient fills again...
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
  8. #8
    Asus P7P55D-E PRO
    Intel Core i7-860
    Education
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Quote Originally Posted by f700es
    Do you mean before or after solid fills?
