Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    6
    Default Help with complex dwg?!
    OK, this is my first post and here is my problem...I'm new to a construction based company & I have had no real introduction to the way they setup dwg's or their standards. I have been given a dwg done by one of teh other employee's & told to "clean it up". It has hundreds of layers & Xref's and about 10 layout's setup. So far my experience has been small building businesses and this new employer is doing some very large construction jobs. I have very little Xref'ing experience& this dwg has many!
    All the layout views actually seem to look OK but my boss wants all the text cleaned up and some walls moved.
    My question is:
    Does anyone have suggestions on how to approach this?
    When I go into Modelspace all layers are visable and its a nightmare, I haven't had any experience with associating layers to viewports. All the work I've done so far is individual dwg's for each layout page, maybe a few dwg's in teh past I've had layers that I've turned on or off depending on which layout I wish to print BUT this job is insane...if I knew how to group layers and switch them on & off I would be able to edit the walls in modelspace.
    Its something I should know but have never learnt..I have edited the various layouts in paperspace so far for the text but I need to make sense of this soon!
    sorry for the long post
    Super Member chulse's Avatar
    chulse's Computer Details
    Windows 7
    17" wide screen laptop w/ 22" acer
    See details...
    chulse's Discipline Details
    Senior Urban Forester
    See details below.
    Tree Preservation Planning for civil design and developent
    Civil 3D 2016
    Jul 2007
    Front Royal, Virginia
    1,320
    Several ways to approach things like this.
    One easy way is to LOCK the viewport in paper space and work through the VP. That way you will only have the layers you want to see for a given VP.
    Otherwise you might try layer states...
    Cary Hulse
    Wetland Studies and Solutions
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    Fjärdhundra, Sweden
    5,148
    One question. is the job to clean up the DWG or the Layouts? As in, will the boss be happy if he can go into the DWG and plot his Layouts and they look good?
    If this DWG is intending to be used more in the future, I think you should spend some more time in Model Space and separate stuff and organize... sounds like a real pita-job
    MTJIGSTRING = BAZINGA
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    A big problem here is that the job of "cleaning up" is usually given to someone who knows what they're doing when someone who doesn't has messed up a drawing.
    My approcah from your point of view would be to go into modelspace (TILEMODE=1) & zoom extents, then go around using the LAYFRZ command to freeze off unrequired layers ensuring that nothing on those layers is still required to be visible... if that is the case you will have to create new layers to be used as visible or frozen off (whichever is easiest)... good luck
    ps... if lot's of xref's are involved ensure VISRETAIN is switched to 1 otherwise you'll have to make any xref layer mods every time you go into the drawing.
    Only the lonely only ... PhotoGallery / Music
  5. #5
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    6
    Quote Originally Posted by chulse View Post
    yeah I have done this for a few of the layouts already but still unsure of what to do with the rest...I don't know about Layer States but I'm researching now
    Tiger - yes, I think the boss will be happy with a general clean up
    Hedgehog - I like your suggestion but I'm not sure if I understand your approach 100%...most just not all
    OH and another thing as I mentioned its about 10 layouts consisting of various floor plans ie. RCP,Electrical & Data,Floor Finishes etc etc, this company tends to have separate dwg files for these types and other separate dwg's for the remaining types of dwg's ie.ELevations, Section & so on....SO I have started saving a copy of the first set of layouts and deleting the other layouts and saving them as individual dwg's, this seems to be working as the individual layouts saved don't bring across the unwanted modelspace objects...I'm hoping once I have done this with all of them I could xref the layouts [I have enough experience to do this, just not really pick up where 743 hours of someone else's work has got this job to now]
  6. #6
    Super Member
    Architecture 2009
    Aug 2007
    Northglenn, Colorado
    713
    You might try the layer management command "lman" and see if there are some saved layer states available to turn on and off
  7. #7
    Forum Newbie
    AutoCAD 2008
    Apr 2008
    6
    thanks Noahma I'll look into that...there was a change of direction within the ofice and teh task was given back to teh person(s) responsible for creating teh drawing, they used by updated verison which was a little bit "cleaner"...not sure how they approached it..to be honest I don't wanna know
    I told them I went in and locked the VP's and froze off layers that weren't being used and cleaned up and matchprop'd text and dimesnions styles but that is as far as I got...I believe the original drawing was done in revit first then xref'd to ACAD...I know nothing of revit, so that probably added to teh confusion.
    thanks for all the responses, I'm making my way thru Mastering AutoCAD 2008 book atm..cheers 20
  8. #8
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    My first response would be:
    Take a deep breath and calm down
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
  9. #9
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    Well, this is a workaround I've mastered. Go into the viewport and when you're there select the text and Mtext you want to clean (change, delete, etc) then copy them to a new drawing make the changes there and copy and paste them back (delete first if necessary).
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
  10. #10
    Full Member joewaianae's Avatar
    AutoCAD 2007
    Aug 2007
    Nebraksa
    89
    This is typical for most companies now a days, in my experience you should just work in the viewports, I think someone mentioned locking the viewport. Do that, and I wouldn't start turning layers off in model because then they wont show up in the viewport, then you wont know what layers to turn back on for that viewport. OR have a copy printed out beside you to ref off of, the text should be no problem in the viewport. Try layiso/layuniso, if your text are all on one layer "more than likely" just iso them and edit everything, the same holds true for your walls that need moving. Its hard to explain through this texting, but if i were there I could help you out because I went through about the same thing. I will tell you that being thrown in like you have been will make you good at it later on down the road.
  1. Complex Solids
    By SilverTiger in forum AutoCAD General
    Last Post: 29th Nov 2008, 04:58 am
  2. 2 complex lisp in one
    By pryzmm in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Aug 2007, 03:09 am
  3. Need Help with complex lines!
    By CAD Intern in forum AutoCAD Beginners' Area
    Last Post: 18th Apr 2006, 08:51 pm
  4. complex shapes ?
    By ddreilly15 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jun 2005, 08:40 am
  5. complex 3-d projects
    By cadnad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th May 2005, 09:28 am
