Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 99
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Default How to determine what files an x-ref is referenced into?
    Is there an easy way to check what drawing files a particular x-ref is referenced into, without going through a series of drawing files which I think the x-ref may be referenced into ?
    In other words, is it possible somehow to select the x-ref file, and check which other drawing files it is then referenced into ?
    Please bear in mind, that variable XREFCTL is set to a value of 0, and therefore has not been creating log files.
    Thanks in advance, for any help or information.
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Yes, within reason...
    I have a routine that will find it files that contain the xref, but there is risk that a few may be missed, although I have never had problems with it.
    Ask nicely and I might try and dig out the script for you.
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    That would be great if you could Leigh please
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    OK. I will see what I can find, it is quite old so may take some time, but I will get back to you as soon as I find it.
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Design Center > Search tab > Look for > Xrefs
  6. #6
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Quote Originally Posted by lpseifert View Post
    That's a useful tip indeed; but in this situation does not find anything
  7. #7
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Are you sure the dwg was being used as an xref?
  8. #8
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Yeah, I'm certain the dwg was being used as an xref elsewhere.
  9. #9
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Quote Originally Posted by LCE View Post
    Any luck with this yet ?
  10. #10
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Still looking through, have found an exe that I know contains it along with a few others, but can not find the script.
    Will check through all my ext hard drives when back in the office tomorrow, must have it somewhere, if not then I will see if I can decompile the exe.
    Sorry for the delay.
  1. Determine Surface areas of 3D solids
    By just4geeks in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jun 2008, 02:15 pm
  2. how to slice referenced 3D objects
    By cadbeginer in forum AutoCAD General
    Last Post: 10th Dec 2007, 10:13 pm
  3. how to determine if a point is inside a region ??
    By maximas2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2007, 06:02 am
  4. Replies: 2
    Last Post: 26th Jul 2007, 11:17 am
  5. Titleblock with referenced coordinates
    By JExpress in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Dec 2005, 04:45 pm
