Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 99
  1. #21
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Thanks Leigh, will have a play with this is the very near future; and let you know how I get on.
    Once again, many thanks.
  2. #22
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    V1.1 uploaded.
    Slight change, will remove the chance of blocks with same name being listed.
  3. #23
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    You are welcome, hope it is roughly what you were after. Isn't great, but isn't awful either...i hope. Make sure to use the most recent uploaded.
  4. #24
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    4 downloads, any comments?
  5. #25
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    I just had a quick look at your work Leigh. One thing I would like to mention here is that all other lisps/vba/ autorun type thingies that load & run with every drawing MUST be either unloaded or switched off, prior to running your code.
    It may be easier to create a separate AutoCAD profile in fact; simply for testing stuff out; that has no customisation added to it.
  6. #26
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Ah, yes, I will see what I can do about that.
    I have some autorun 'thingies' at my end though, and have had no problems...
    Thanks.
  7. #27
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    It's no big deal Leigh. I should have realised not to test anything anyway, without creating a separate Testing profile.
    One thing that did happen, however, is that it ran into a JIT error, specifically "Cannot write to a closed TextWriter"
    I have no idea what that means; but it happened as soon as the second drawing was opened, which contained the exact same x-ref that the first drawing in the series had.
    Then in the text file it generates as it runs through; it had only listed the first drawing that contained the x-ref in question. I guess that would be normal if it error'd out on the 2nd one.
    Let me know if you need any other error codes about this issue.
  8. #28
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Nope, that 1 makes sense. will fix it now and then re-up it.
    Thanks.
  9. #29
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    Version 1.2 attached.
  10. #30
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Thanks Leigh.
    Just wanted to give you feedback. When run, this found no errors this time
    Excellent stuff
  1. Determine Surface areas of 3D solids
    By just4geeks in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jun 2008, 02:15 pm
  2. how to slice referenced 3D objects
    By cadbeginer in forum AutoCAD General
    Last Post: 10th Dec 2007, 10:13 pm
  3. how to determine if a point is inside a region ??
    By maximas2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2007, 06:02 am
  4. Replies: 2
    Last Post: 26th Jul 2007, 11:17 am
  5. Titleblock with referenced coordinates
    By JExpress in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Dec 2005, 04:45 pm
