one left sorry
Two left sorry
If you make an annotative text style with 'Match text orientation to layout' and use the style for your attribute, the text will stay horizontal if you rotate the block or insert it with a rotation.
Not to sound dumb but how you do that?
Bump. I've tried the annotative text/orientation trick, but it doesn't seem to work.
Anyone have ideas? I'm looking to do the same thing.
I would like to ask in amendment to this question, how do you keep the text at 0 degrees, if you were to rotate an object and a text, say 90 45 degrees, but keep the text at 0 degrees the entire time. (for example, 2 blocks, 1 above the other, the top one has the text, and you make the center of rotation to the bottom block, and when you rotate the top part, the text and the block rotates to the degrees, and I would like the text at 0 degrees)
