+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Junior Member
    Using
    Map 3D 2009
    Join Date
    May 2008
    Posts
    17
    Default AutoCAD Bible 2008
    Hi all, I have a copy of the 2008 Finkelstein AC/LT "Bible"
    and I am having some concerns about the DVD.
    First off, if I try to install the trial software, I get the message "DWG Viewer location is not empty". Now I know that's because I already have a full version of the Map 3D installed, but will it interfere if I try to intall the trial software anyway?
    Second, I can't open the drawing files included on the DVD in either LT 2005 or in Map 3D. What gives?
    I really need to practice because I'm expected to do drawings in 3D within a few weeks at work!
    Thanks
  2. #2
    Senior Member architecture68-raff's Avatar
    Using
    ADT 2005
    Join Date
    Nov 2006
    Location
    Chicago, IL
    Posts
    159
    Default
    Quote Originally Posted by Natman View Post
    The drawing files on the DVD are likely in a 2007 dwg format. This explains why LT 2005 won't open them. What version of Map 3D do you have? You can convert the files on the DVD down to the 2004 dwg format by copying them to your hard drive and using the converter included in the free DWG TrueView
    If it were me, I'd avoid installing any other trial software or viewers from the CD
    Andy -- Chicago, Illinois
    ADT 2005, Revit Architecture 2009, Sketchup 7
  3. #3
    Junior Member
    Using
    Map 3D 2009
    Join Date
    May 2008
    Posts
    17
    Default
    Hmm, it may not be worth it then. The Map 3D version is 2009.
Similar Threads
  1. AutoCAD 2008 and AutoCAD LT 2008 Bible by Ellen Finkelstein
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 17th Oct 2011, 01:07 am
  2. AutoCAD 2008 and AutoCAD LT 2008 Bible published!
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 4th Aug 2007, 09:31 pm
  3. Learning from the AutoCAD Bible...
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 3rd Jul 2007, 03:30 pm
  4. Available for Pre-Order! - AutoCAD 2008 and AutoCAD LT 2008 Bible
    Last Post: 16th Jun 2007, 08:51 pm
  5. Mistakes in AutoCAD 2006 Bible??
    By herewewere in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2006, 01:28 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
