Closed Thread
Results 1 to 1 of 1
  1. #1
    Administrator CADTutor's Avatar
    Computer Details
    CADTutor's Computer Details
    Operating System:
    Windows 7 Home Premium 64bit
    Motherboard:
    Asus P7P55D-E PRO
    CPU:
    Intel Core i7-860
    RAM:
    4GB PC3-12800 C8 Corsair Dominator
    Graphics:
    NVIDIA Quadro FX 1800 768 MB
    Primary Storage:
    Intel X25-M SSD 160GB
    Secondary Storage:
    Samsung Spinpoint 320GB
    Monitor:
    BenQ FP241W 24" Wide
    Discipline
    Education
    CADTutor's Discipline Details
    Occupation
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Discipline
    Education
    Using
    AutoCAD 2014
    Join Date
    Aug 2002
    Location
    Hampshire, UK
    Posts
    3,606
    FAQ Article Autodesk Student Software
    Student Software
    Q: I'm a student, can I get AutoCAD and other Autodesk software for free?
    A: Yes, you can.
    You can download free full-working versions of Autodesk software from the Autodesk Student Community site provided you are a registered student at a recognised college or university.
    In order to prove you are a registered student, you will need to sign up at the Student Community site using your college or university email address.
    Getting the software
    To get your free software, follow the link above to the Student Community site and sign-up using the email address given to you by your college or university.
    Your log-in details will be sent to the email address you used to sign-up. Once you have them, you can log-in and go to the Software Downloads page. There, you will find a long list of downloads. Try them all if you want but make sure you have a fast internet connection; some of the downloads are over a gigabyte!
    Student editions
    Although the available applications are full working versions, they are student editions and are not the same as commercial versions. For example, they can only be used for 12 months - that's fine if you are still a student in 12 month's time because you can just download a newer version. Also, some of the applications may have overprints. AutoCAD will print a border around any print that says "PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT ". Saved DWG files will also be marked as the same and will cause an alert if opened in a commercial product.
    Do bear in mind that the educational license for these products does not allow their use for commercial purposes.
    Available Software
    At the time of writing (May 2009), the following are available for download:
    Revit Architecture
    Revit Structure
    Autodesk Robot Structural Analysis Professional
    Revit MEP
    Autodesk Navisworks Manage
    Autodesk Ecotect
    Green Building Studio (web based service)
    AutoCAD (vanilla)
    AutoCAD Architecture
    AutoCAD Civil 3D
    AutoCAD Electrical
    AutoCAD Inventor Professional
    AutoCAD Map 3D
    AutoCAD Mechanical
    AutoCAD MEP
    AutoCAD Raster Design
    Autodesk 3ds Max (30-day trial only)
    Autodesk Alias Automotive
    Autodesk Impression
    Autodesk Maya (30-day trial only)
    Autodesk MotionBuilder
    Autodesk Mudbox (30-day trial only)
    Autodesk Showcase
    Autodesk SketchBook Pro
    Autodesk VIZ
    As of the 2010 versions, vanilla AutoCAD is available and not just the vertical products.
    Serial number
    When your software is installed, you will need to register it using the serial number provided to you at the time of download. Don't worry if you lose your serial number, it can be found against the software you downloaded any time you log-in. Further instructions can be found at the Autodesk Student Community site.
    Don't forget, you will also find lots of helpful support materials at the Student Community site in addition to the downloads.
    Last edited by CADTutor; 7th May 2009 at 12:50 pm. Reason: Updated for 2010 versions
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
Similar Threads
  1. Free AutoDesk software?
    By ReMark in forum Software & Licensing
    Last Post: 3rd Nov 2011, 07:31 am
  2. Which autodesk software for cabinets?
    By Lucid in forum AutoCAD Drawing Management & Output
    Last Post: 26th Nov 2007, 01:05 pm
  3. Autodesk Student Community
    By jdkriek in forum Useful Links
    Last Post: 20th Nov 2007, 10:43 am
  4. Replies: 0
    Last Post: 3rd Jul 2007, 09:40 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
