dms256@gmavt.net Posted May 8, 2008 Share Posted May 8, 2008 How do you add exterior building details such as siding and trim around windows? Quote Link to comment Share on other sites More sharing options...
GhostRider Posted May 8, 2008 Share Posted May 8, 2008 for 2-d applications Several Hatch patterns work well for siding, vert. or horz. shake.. etc. window trim can be a simple rectangle for lineals or possibly a block for more complex trim. If it's for 3-D or renderings you may want to look into MATERIALS from the Render menu. Quote Link to comment Share on other sites More sharing options...
RFRUSSO Posted May 9, 2008 Share Posted May 9, 2008 I love this question. I handle this differently the the rest of the guys in our CAD group. This is how I do it: Once you have the out line of your building, add a hatch. Use as may closed Polly lines as you can. Don't worry about windows, doors or any thing else for that matter. If your elevation needs some thing like 4' of CMU with metal siding above and then a standing seem metal roof, you would draw a rectangle for each and then add the appropriate hatch. Now for adding the windows, doors and lovers. For each variation of the above, create a block with a wipeout and just drop them in place. That way as things move or change, there is no trimming or rehatching. Go ahead and take a look at the attached drawing. Move things around to see how I have used the wipeouts to improve the efficiency of working with this drawing. Also not that I have only used wipeouts in blocks. That is to keep from ending up with stray wipeouts though out the drawing. sample elevation.zip Quote Link to comment Share on other sites More sharing options...
Noahma Posted May 9, 2008 Share Posted May 9, 2008 I love this question. I handle this differently the the rest of the guys in our CAD group. This is how I do it:Once you have the out line of your building, add a hatch. Use as may closed Polly lines as you can. Don't worry about windows, doors or any thing else for that matter. If your elevation needs some thing like 4' of CMU with metal siding above and then a standing seem metal roof, you would draw a rectangle for each and then add the appropriate hatch. Now for adding the windows, doors and lovers. For each variation of the above, create a block with a wipeout and just drop them in place. That way as things move or change, there is no trimming or rehatching. Go ahead and take a look at the attached drawing. Move things around to see how I have used the wipeouts to improve the efficiency of working with this drawing. Also not that I have only used wipeouts in blocks. That is to keep from ending up with stray wipeouts though out the drawing. [ATTACH]5825[/ATTACH] I might have to give this method a try at work monday, I hate having to update hatches after we move something. Quote Link to comment Share on other sites More sharing options...
ricaroofers Posted February 12, 2010 Share Posted February 12, 2010 Several Hatch patterns works well for siding. It is a lot easier to do compared to other techniques. You just need some step by step guide to make it perfect. Roofers Quote Link to comment Share on other sites More sharing options...
Tankman Posted February 12, 2010 Share Posted February 12, 2010 Very nice 'n simple RFRUSSO! I'm going to "play" with your instructions over the weekend. I don't ski and there's 2+ feet of snow outside. And, get this, the woodstove is indoors along with two days of fire wood! Thanks for the well explained routine! Quote Link to comment Share on other sites More sharing options...
