Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Forum Newbie
    AutoCAD LT 2008
    May 2008
    2
    Default Cut & Paste hangs between drawings
    Within AutoCAD LT 2008, I have two drawings open. I can click on an entity and right-click copy, with no problem. When I activate the other drawing and right-click paste, it may take up to 5 minutes before the entity is pasted. The entity can be as simple as a single line. The machine is a new dual-core machine with 3G of ram. I believe it may be an issue with the drawing, however I have gone through the process of cleaning and purging, but still no luck.
    Please help.
    Kind regards,
    Harley
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    OK, and what are the results if you start 2 new drawings, draw and line in 1 then cut and paste it to the other?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Does the drawing have a number of X-refs attached?
    Full Member Opc 12's Avatar
    Inventor 2010
    May 2008
    South Africa (JHB)
    59
    I had a similar problem, my pc was to slow and i didn't have enough ram.
    That could be your prob.
    By the way how big is the copied section if it is rather large then that might be your prob.
    Try take a smaller piece to a new drawing.
  5. #5
    Inventor 2010
    May 2008
    South Africa (JHB)
    59
    Check that there is no associative hatch?
  6. #6
    Forum Newbie
    AutoCAD LT 2008
    May 2008
    2
    The two drawings could be empty apart for a single line and the same problem would happen.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Please take a look at similar threads by using the Search option above. As your search criteria use the phrase "cut & paste". If you don't find a solution among the available responses that works for you please post back and we'll put our collective heads together and see if we can help solve your problem. Works for you?
  8. #8
    Forum Newbie
    AutoCAD LT 2008
    Jun 2008
    2
    Question cut/paste hanging in AutoCAD LT 2008
    I was wondering has anyone had any success in finding out why some drawings were hanging when cut/pasting- I have similar problems because I do tend to do a lot of cut and pasting from various drawings etc. I have noticed that even if I purge the drawing - my drawings are slower to cut/paste in than another drawing using the same template, this is after I have cut/paste larger drawings or sections into it. The file size has only slightly increased from the main template, and I may have even deleted the items I pasted in as I only used them temporarily.
    I have tried different machines with high specs and loads of ram. I have also cleared out the PC's cut/paste clipboard and even purged all temp files. It "appears" the cad file still contains some hidden information??? Has anyone else come across this – I have only noticed this occurring in version 2008
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Check this out. Note that at the bottom there is a reference to 2008.
    http://usa.autodesk.com/adsk/servlet...linkID=9240617
  10. #10
    Forum Newbie
    AutoCAD LT 2008
    Jun 2008
    2
    Default cut/paste nightmare
    Thank you Mark - that was it!!!!
  1. Can't Copy and Paste Between Drawings
    By WireGuy1950 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Sep 2012, 04:41 am
  2. Cannot copy and paste between drawings
    By KRENG in forum AutoCAD Beginners' Area
    Last Post: 16th Nov 2011, 03:07 pm
  3. Convert Multiple Tab Drawings to Individual drawings
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Mar 2008, 05:35 pm
  4. Unable to copy and paste between drawings
    By Russell H in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Mar 2008, 12:55 pm
  5. Making AutoCAD drawings look like hand drawn drawings
    By ron1976uk in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2004, 01:17 pm
