Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2007
    Sep 2007
    3
    Default Inches to Metric
    If I have a drawing done in inches, is there an easy way to convert Dims and all into metric?
    Super Member Raggi_Thor's Avatar
    AutoCAD 2008
    Aug 2007
    Trondheim, NORWAY
    718
    Short:
    Copy paste everything to a metric drawing (based on a metric template.
    Scale everything with a factor 25.4.
    Select all dimensions and change dimstyle (right click and select from menu).
    Mvh, Kvedja, Kind Regards,
    Ragnar Thor Mikkelsen
    http://www.DESIGNDATA.no/English.htm
    Super Member chrisdarmanin's Avatar
    chrisdarmanin's Computer Details
    win 10
    HVAC
    chrisdarmanin's Discipline Details
    Building Services Draughtsman
    HVAC
    AutoCAD 2018
    Feb 2006
    Malta
    562
    i sometimes receive drawings that are in mm but units are set to inches, in that case all i have to do is change the units to mm by going to Format>units... or typing UNITS
    Senior Member CADguy209's Avatar
    AutoCAD 2013
    May 2008
    Stockton, CA
    110
    Do you want to just be able to display the Metric units? If so just go to your dimstyles, alternate units and turn 'display alternate units' on.
    If you want to actually scale the part up so that its "in metric units" than just scale it up by the usual conversion factor.
  1. All inches instead of feet and inches
    By siderus in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2009, 11:01 am
  2. convert drawing in inches to metric?
    By scubadoo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Apr 2008, 04:28 pm
  3. Convert Feet & Inches Drawing into Metric??
    By Unick in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2007, 03:39 pm
  4. Converting metric to inches
    By zimtok in forum AutoCAD Drawing Management & Output
    Last Post: 25th May 2007, 08:16 pm
  5. scale a metric drawing to inches in viewport?
    By ylime in forum AutoCAD General
    Last Post: 4th Jan 2007, 04:54 pm
