Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Advanced Offset
    Full Member Arch_Eric's Avatar
    ADT 2006
    May 2008
    Texas
    25
    Smile Advanced Offset
    My biggest peev with Audocad's offset command is you can't change the offset distance in the middle of the command. You also can't just tell it to offset an object say 10 times to one side. So here's my advanced offset command.
    Notes on the command:
    1) Using the multiple command before selecting an object lets you define how many times to offset an object; using multiple after selecting an object works exactly like the built-in offset's multiple works (offset each time you click)
    2) Change your offset distance at almost any time!
    3) The rest of the options work just like the original offset.
    This code is fresh and tested only to work. If you experience any problems, let me know. If you want to rewrite something in it, feel free to do so.
    Code:
    Updated code. See below.
    ADT 2006
    May 2008
    Texas
    25
    Some updated code after using it a bit. Asks for the initial offset distance every time (with default of last offset).
    Code:
    Updated again. See below.
    Senior Member
    AutoCAD 2009
    Mar 2007
    475
    works great except for the amount of times you want to offset if you enter ten times to offset it only does about 2 or 3
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    Quote Originally Posted by Arch_Eric View Post
    Code:
    Good stuff. You should post it here, in the AutoLISP Archive for future reference as well: http://www.cadtutor.net/forum/forumdisplay.php?f=30
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  5. #5
    ADT 2006
    May 2008
    Texas
    25
    Smile
    MikeP: I got that fixed. Was brought to my attention elsewhere.
    Code:
    Code updated.
  6. #6
    Junior Member
    AutoCAD 2004
    May 2008
    17
    Default add this?
    Can you add this code [current/match layer offset], maybe hightlight the entity too would be nice.
  7. #7
    ADT 2006
    May 2008
    Texas
    25
    Hey Tader,
    I was already working on that code, and finally finished it tonight. I went a little further with it. In addition to being able to select Source or Current, you can enter any valid layer name. I've been working out bugs all night and I think I worked out most of them.
    Let me know what you think.
  8. #8
    Junior Member
    AutoCAD 2004
    May 2008
    17
    That's sweet. I'll run it quite often & let you know of any bugs. Thnx again as I'm sure many others will enjoy it.
  9. #9
    Junior Member
    AutoCAD 2004
    May 2008
    17
    Hey Eric, I was thinking: rut ro, if you replaced the "Layer" option with "Layer" "Current" which would make your 1st prompt [Specify offset distance [Through/Current/Source/Exit] <Through>: this would save the user one keystroke if he/she wanted to offset in layer. I was poking around in there to do it myself, but I usually mutilate anything I touch.
  10. #10
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Hey Eric,
    Thats cool, i like it, beats faffing with the array dialog..
    My only thoughts would be to include the whole procedure for the multi offset in one undo. If you want to undo it now, each undo click only does one line at a time..
    Cheers,
    PaulRenegade @ hardwiredstudios..
    XP Pro / AutoCAD 2007 : Pentium Core 2 Q6600 Quad Core : ASUS P5N-E SLI Motherboard : 4GB DDR2 RAM : 2 x SLI NVIDIA 8500GT SLi 1024MB DDR2 PCI-Express Graphics Cards
  1. offset
    By GREG in forum AutoCAD Beginners' Area
    Last Post: 9th Sep 2007, 04:18 am
  2. Advanced Trim
    By daiharv in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2007, 10:25 am
  3. Advanced Modelling Extersor
    By youngken in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jun 2005, 09:33 am
  4. offset
    By joiner in forum AutoCAD Beginners' Area
    Last Post: 5th Apr 2005, 04:44 pm
