Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2007
    May 2008
    7
    Default Viewing how Previous Objects were Created.
    I'm trying to recreated a drawing, I did awhile ago on AutoCAD 2007 and I can't remember how I created a object. So I was wondering if there is a way I can look on the orginal drawing and somehow see how I created the object.
    Thanks.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    2D or 3D?
    You can get limited information through LI (list) or maybe Properties.
    In some cases you can even change the geometry dimensions in the Properties.
    Attach your file here if you can't figure it out.
    Forum Newbie
    AutoCAD 2007
    May 2008
    7
    It's in 2D. I know how to get the properties, but what i'm looking for is to be able to view how it was created. For example if I had a circle and wanted to know how it was created I could somehow view it and it would show me that I used the ttr command or something like that. I know theres a way to view the time your objects were created and that, so I figured there would be a way to view the command used to created them.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Jon B View Post
    ...so I figured there would be a way to view the command used to created them.
    F2, but I suspect it is a little late for that in this case. Attach what you have.
  5. #5
    Forum Newbie
    AutoCAD 2007
    May 2008
    7
    I'm trying to remember how I created that circle so that it perfectly intersects the 3 points. I tried using the 3P command but it isn't working.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Draw>Circle>Tan,Tan,Tan
  7. #7
    Forum Newbie
    AutoCAD 2007
    May 2008
    7
    I got it, thanks.
  8. #8
    Forum Newbie
    AutoCAD 2007
    May 2008
    7
    If anyone knows how to view commands used to created previous objects that will not be erased over time let me know. Will really help with other drawings.
  9. #9
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Maybe the Action Recorder is what you are looking for -
    http://usa.autodesk.com/adsk/servlet...112&id=9106363
  1. Creating .bak when .sv$ are created
    By Steve Dave in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2006, 07:56 pm
  2. I have a block I created but..
    By newbie12345 in forum AutoCAD General
    Last Post: 27th Feb 2006, 01:14 am
  3. Created a .dxf
    By Tristan in forum AutoCAD Beginners' Area
    Last Post: 5th Jan 2006, 11:55 pm
  4. viewing dragged objects
    By jfigaro in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2005, 05:18 pm
