Results 1 to 4 of 4
    Junior Member
    Architectural DT 2008
    Jan 2008
    12
    Default Cant open the window for open or save
    When I try to open a file in the open window it dont dissapear I have to write it in in the command field ?
    What should I do ?
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Filedia=1
    You may want to have a look here
    Junior Member
    Jan 2008
    12
    Default If found the answer on the foroum
    Write: Filediand chosse 1
    Junior Member
    Jan 2008
    12
    thanx Ipseifert
  1. Open/save problem
    By littlem in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2007, 05:17 pm
  2. 2007 - open & save as: no browser window
    By designer_geek in forum AutoCAD Drawing Management & Output
    Last Post: 7th Feb 2007, 01:04 am
  3. Open File Window
    By pasquale in forum AutoCAD Drawing Management & Output
    Last Post: 19th Sep 2005, 04:43 pm
  4. no file open window
    By ledo in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2005, 03:33 am
  5. Open drawings window
    By stargirl in forum AutoCAD Beginners' Area
    Last Post: 12th Jan 2004, 04:40 pm
