Reset the UCS in each viewport to the same.
Although I pesonally would have top=plan view, side =elevation, and one SE ISO.
Nick
I am trying to have a number of viewports for a 3d drawing. However, the axis changes in each viewport e.g when I draw a line along the x axis it is on the z axis in another viewport. How can I make the axis simultaneous within each viewport? thanks
Nick
http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
http://s240.photobucket.com/albums/ff241/dyNick_Scots/
http://designgraphicsshowcase.blogspot.com/
High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
Home - AMD 2.1GHZ - 512Ram, 64 Video,
Laptop Inventor 7, Autocad 2004, Corel 11
In each viewport you can change the VPOINT to whatever you want, if you're after a fairly standard view you want it to be 0,0,1- although you can change one to match another by simply running the command- it will show what it's currently set to.
Also make sure UCSFOLLOW is set to 0 (I think!).
For anyone wondering, this isn't a translation of above post.
"To alcohol; the cause and solution to all of life's problems." - Homer Simpson
