Guest g-dub Posted February 5, 2005 Share Posted February 5, 2005 Hi there Without using the "ID" command to start a line, can I track from the end of a line (or on an angle) by selecting the first ref point and inputting the distance using the number keys. i.e-- I want to draw a line at right angles to my base line starting 100mm along its length. Another quick one....Is there a keyboard shortcut to periodically save instead of clicking on the icon all the time ? Cheers............gdub (p.s I'm new here ) Quote Link to comment Share on other sites More sharing options...
Mr T Posted February 5, 2005 Share Posted February 5, 2005 Tracking does not draw anything. Go into OPTIONS then set the autosave timing. Nick Quote Link to comment Share on other sites More sharing options...
CADTutor Posted February 5, 2005 Share Posted February 5, 2005 If you want to draw a line 100 units in from the end of another, you can. Make sure you have both OSNAP, POLAR and OTRACK turned on and that Endpoint is one of your running object snaps. Start the line command, hover over the end of the existing line until you see the endpoint icon, point the cursor along the line, using polar to snap to horizontal (assuming the first line is horizontal), enter 100 at the keyboard, point the cursor in the other direction (vertical) and enter the length of line you want. That's it. Mr T's comments are sometimes rather abrupt. Welcome to the forum Quote Link to comment Share on other sites More sharing options...
Guest g-dub Posted February 5, 2005 Share Posted February 5, 2005 Thank's for that, and thank's too for the welcome gdub Quote Link to comment Share on other sites More sharing options...
Mr T Posted February 6, 2005 Share Posted February 6, 2005 Abrupt ? Just short and to the point. Use ORTHO and DDR. Direct distance entry. So click on a start point then type in a lentgh,use ortho and enter. Does that help ? Need more advice ? Welcome to the forum. Nick Quote Link to comment Share on other sites More sharing options...
Guest g-dub Posted February 20, 2005 Share Posted February 20, 2005 Hi again Mr T I've only just seen this reply. Short and to the point is cool, as they say in certain circles "Just the basic facts Sir" Thanks for the help and the welcome.....................g Quote Link to comment Share on other sites More sharing options...
Kate M Posted February 22, 2005 Share Posted February 22, 2005 Ctrl+S is the keyboard shortcut for QSAVE... Quote Link to comment Share on other sites More sharing options...
erona Posted February 23, 2005 Share Posted February 23, 2005 Ctrl+S is the keyboard shortcut for QSAVE... So that's the shortcut for that I've been typing QSAVE all this time. Quote Link to comment Share on other sites More sharing options...
Guest g-dub Posted February 23, 2005 Share Posted February 23, 2005 Thanks Kate The first lesson I had drummed into to me regarding my CADwork, and continually since was "Constantly save thy work " and not to risk a possible mental breakdown by trusting to the Autosave option. So thanks for that. Having to click the save icon with the mouse could sometimes be a wee bit of a pain by interupting the creative flow....or something like that. Cheers............g Quote Link to comment Share on other sites More sharing options...
Guest Kimi Posted June 22, 2005 Share Posted June 22, 2005 Hello everyone. This is my first post here.. Sorry for the thread resurrection, but I need some help and found this using search. If you want to draw a line 100 units in from the end of another, you can. Make sure you have both OSNAP, POLAR and OTRACK turned on and that Endpoint is one of your running object snaps. Start the line command, hover over the end of the existing line until you see the endpoint icon, point the cursor along the line, using polar to snap to horizontal (assuming the first line is horizontal), enter 100 at the keyboard, point the cursor in the other direction (vertical) and enter the length of line you want. That's it. This method doesn't seem to work with my AutoCad 2005LT. I also can't find the OTRACK command anywhere. I have endpoint turned on in snaps. With the AutoCad in my school I can use the "hover over end of the existing line..." thingy. I installed 2005 LT at work today and can't find a way to turn on this same feature. Any help would be greatly appreciated... Quote Link to comment Share on other sites More sharing options...
Kate M Posted June 22, 2005 Share Posted June 22, 2005 Sorry, Kimi -- OTRACK doesn't exist in LT. Welcome to the forum though -- hope you have better luck with your next question. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted July 28, 2010 Share Posted July 28, 2010 to draw a line 100 units from end of another, I use following procedure: start line command when it asks for first point, enter: from it asks for base point, then choose the point you want to offset 100 units from then track over the line in the direction you want (right or left, in case of horizontal distance) enter the distance, in your ex 100 units This gives you the first point when it asks for second point, enter the distance and angle for second point. This method is very close to what CAD Tutor replied except s/he didn't use from command. I hope you like this method. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 29, 2010 Share Posted July 29, 2010 Autosave is bad advice. OP should use QS and save often. Quote Link to comment Share on other sites More sharing options...
