Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Hmm I can't get the UCS to follow my view with it set at 1 or 0 or even using plan, and I tried with Vanilla as well, maybe I'll step out of this one...
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
  2. #12
    Senior Member CADguy209's Avatar
    AutoCAD 2013
    May 2008
    Stockton, CA
    110
    Im still not sure what exaclty the TC is trying to accomplish.....
  3. #13
    Forum Newbie
    AutoCAD 2009
    May 2008
    4
    well, the thing is, is I'm using the viewcube to navigate. and I can't draw on anything but the XY plane. I'll try that UCSFOLLOW thing. see if it works.
    I havent tried doing the traditional view>3d views>front left back etc in 2009 yet. I would doubt that it still works. I'm just talking about navigation with the viewcube.
  4. #14
    AutoCAD 2013
    May 2008
    Stockton, CA
    110
    If youre working in 3D, and I assume making a model, and you want to draw on the XY plane why dont you try setting up and saving your ucs's in 90 degree intervals relative to your model (front face, right side, top, etc) or using ucs 3 point? If you are creating features on a model your still going to have to draw your base objects on the xy plane anyways, its really not all that different from doing a 2D drawing.
    This way you can keep your Viewpoint stationary and rotate your ucs around the model as needed in order to draw what ever features you need on their respective faces/planes. You can also save your Viewpoint and then restore it if you need to do a 3DO or some other view viewing oreintation.
    Hope that helps.
  5. #15
    Forum Newbie
    AutoCAD 2009
    May 2008
    4
    okay, I tried both UCSFOLLOW to 0 and 1, and when I set it to one It immediately jumps to XY(top). same with "plan". If the viewcube doesn't set the "drawing plane" to the way I'm looking at then what is its point of it?
  6. #16
    Forum Newbie
    MEP 2010
    Jun 2010
    1
    Default To draw on the current view
    after you have navigated with the view cube you can set the plain by entering the following commands: UCS VIEW
    that will make your current view the surface on which you are drawing and to set the depth or z, enter this command: UCS MOVE
    then select the a point.
  7. #17
    Forum Newbie
    AutoCAD 2011
    Jun 2015
    3
    Default XY YZ XZ planes by pressing Function Key F5
    XY YZ XZ planes by pressing Function Key F5, snap should be ON
    in details : http://www.mechanicalengineers.co/co...tocad-keyboard
  8. #18
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    The F5 function key is used to toggle between isoplanes (left, top and right) when doing a 2D isometric drawing. It is of no use in a 3D drawing.
  1. Replies: 5
    Last Post: 3rd Dec 2007, 02:46 pm
  2. Drawing stairs from the xy-plane
    By Siberian in forum AutoCAD General
    Last Post: 2nd Jan 2007, 02:43 am
  3. Replies: 3
    Last Post: 13th Jun 2006, 12:44 pm
  4. How do I change the drawing scale?
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2006, 10:08 pm
  5. Can I change the target for New Drawing?
    By Cadastrophic in forum AutoCAD Beginners' Area
    Last Post: 8th Dec 2003, 08:14 pm
