tharney Posted May 23, 2008 Share Posted May 23, 2008 When I print a single sheet to PDF I have no issues. However, when I try to use the publish command I get this error ERROR: The current device does not support the requested media size. I'm using the same cutePDFwriter and page layout as I did with the single sheet. Also my 2 co-workers are using the same settings for what I can tell, and have no problems. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
GE13579 Posted June 7, 2008 Share Posted June 7, 2008 Have you tried it using Sheet Set Manager instead? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 7, 2008 Share Posted June 7, 2008 It sounds like one of your sheets is not set up correctly. Have you checked your page setup for each layout to make sure they are all set the same? Quote Link to comment Share on other sites More sharing options...
jtk07 Posted March 3, 2010 Share Posted March 3, 2010 I am currently having a very similar issue, When We send a Publish and select the sheets we want to publish we change the page setup to read for all sheets (PDF is a page setup we have made) and print we get following message. ERROR: The current device does not support the requested media size. When we publish and set all sheets to PDF we get one binder pdf not individual sheets. Any help would be greatly appreciated!!! Jon Quote Link to comment Share on other sites More sharing options...
jamesfear Posted March 15, 2010 Share Posted March 15, 2010 I'm not quite sure if this will help but I just recently had the same problem. I could plot but would get this error "ERROR: The current device does not support the requested media size." when I tried to publish. The way I fixed it was simply recreate the page setup, same setting and everything but saved as a differant name. I think the reason I got the problem was I created the page setup from AutoCAD 2010 and I'm using a AutoCAD 2009?? Yeah hope this helps James. Quote Link to comment Share on other sites More sharing options...
benamine Posted January 11, 2012 Share Posted January 11, 2012 this did the trick for me. "simply recreate the page setup, same setting and everything but saved as a differant name." Thanks, James. Quote Link to comment Share on other sites More sharing options...
