Results 1 to 9 of 9
Thread: Break Line Lisp
    Senior Member neekcotrack's Avatar
    MEP 2009
    May 2008
    Florida
    329
    Smile Break Line Lisp
    Does anyone know of a lisp that if you click on a intersection of two lines, then click the line you want to break it breaks on both side evenly depending on what the LTscale is set to?
    Thanks in advance for any advise and help!
    Full Member grouch19's Avatar
    Map 3D 2008
    Mar 2008
    55
    not sure if this will help but i would use drawing cleanup and select break crossing objects. Only thing is it would turn 2 intersecting lines into 4 separate lines...
    If it aint broken don't touch it
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    5,997
    alan butler's breakall routine has the option to set an offset in each side of the break b/w lines. you can find it at theswamp. an older version was posted at cadalyst.
    Map 3D 2008
    Mar 2008
    55
    there you go!
  5. #5
    Full Member filan1a's Avatar
    AutoCAD 2006
    Mar 2008
    73
    Breakall
    see the attachment below.
    Quote Originally Posted by neekcotrack View Post
  6. #6
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    Quote Originally Posted by filan1a View Post
    Breakall
    That's an older version.
    Here is the latest.
  7. #7
    Forum Newbie
    AutoCAD 2008
    Jul 2010
    2
    I hope to create new lisp to trim line but after I put the block, I need to make two points data as subentity using entnext I don't want to use attribute data because the block contains 4 lines attributes.
  8. #8
    Forum Newbie
    AutoCAD 2012
    Aug 2012
    1
    Quote Originally Posted by CAB View Post
    Here is the latest.
    This Lisp is great. Thanks a lot
  9. #9
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    You're welcome.
    Newer version found here http://www.theswamp.org/index.php?topic=10370.0
  1. How to break a line when inserting a block?
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Feb 2012, 03:46 pm
  2. Break a line at a single point
    By Lucid in forum AutoCAD General
    Last Post: 20th Dec 2007, 10:55 pm
  3. break-line symbol
    By cadmench in forum AutoCAD Beginners' Area
    Last Post: 12th Dec 2007, 06:40 pm
  4. break layer and line thickness
    By sharlon in forum AutoCAD General
    Last Post: 25th Mar 2006, 02:23 pm
  5. AUTOMATIC BREAK/TRIM A LINE WHEN INSERTING A SYMBOL
    By Frederik in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2005, 08:52 am
