Results 1 to 3 of 3
    Super Member
    Dipali's Computer Details
    windows vista
    IBM Thinkpad lenovo
    Intel Centrino vPro
    viewsonicVA1916w
    Architectural
    Dipali's Discipline Details
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2009
    Dec 2007
    INDIA
    1,058
    Default Hatch Scale Problem
    I have to do dot hatch in several plans woth the scale 2800 as provided in sample plan. for some reason I ma not able to see that hatch in the drawing but by isolating that layer, i have been able to select & seet he properties of it.
    When I am doing the hatch using same properties, it says that 'Hatch spacing too dense, or dash size too small. I can seet the hatch only if i set the scale to 6200 or more, which results in to less dense hatch. (I have the pdf of sample file as well so I can compare)
    Any workaround to make the hatch simialr?
    "An architect's most useful tools are an eraser at the drawing board & a wrecking bar at the site."
    Frank Lloyd Wright
    Senior Member AVITWeb's Avatar
    AutoCAD 2011
    Dec 2006
    New Jersey
    152
    Quote Originally Posted by Dipali View Post
    You could try adjusting your LIMITS in the drawing, but I fear that the size of the drawing itself is causing you problems. You may be able to hatch the area if you zoom in on it. Can you zoom in so that the area you are trying to hatch is the only thing visible on your screen? This may help, but keep in mind that if you zoom out, the hatch will look really dense.
    Stand back or I will explode ALL of the dimensions!!!
    Super Member
    windows vista
    IBM Thinkpad lenovo
    Intel Centrino vPro
    viewsonicVA1916w
    Architectural
    ARCHITECTURE
    Architectural
    interiors
    AutoCAD 2009
    Dec 2007
    INDIA
    1,058
    Quote Originally Posted by AVITWeb View Post
    Thanks for the suggestion. I think you are right it about problem being the size of the drawing. The area I am hatching is relatively very large. I tried the same hatch in smaller area & its working so I divided the area in parts did the hatch of parts one by one. that way it is appering the way I need, so thanks for that
    But would still like to know if there is a way to do the entire area hatch in one go
    Changing limits or switching them on or off is not helping. may be you can help further by explaining the relationship between limits & hatch scale so how to determine the new limts?
    Frank Lloyd Wright
  1. Hatch Scale
    By cmcd in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2009, 07:43 am
  2. HATCH Scale Help
    By quixin in forum AutoCAD Beginners' Area
    Last Post: 18th Feb 2008, 08:52 pm
  3. Hatch Scale
    By THE JACK in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Feb 2008, 12:21 pm
  4. Hatch scale
    By happyunited in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Feb 2008, 04:05 pm
  5. hatch pattern scale
    By allanp in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Dec 2005, 02:25 pm
