Results 1 to 3 of 3
    Junior Member
    AutoCAD 2004
    Aug 2007
    16
    Default New to lisp commands
    Hello
    I am new to lisp files and can't find what I'm looking for anywhere else. I have an OFFSET TO LAYER lisp file that works, but after one use requires wont repeat like most commands. What do I need to add to the code below to make it repeat untill told not to?
    Thanks
    (defun Ctl()
    (setvar "cmdecho" 0)
    (setq c_layer (getvar "clayer")
    last (getvar "offsetdist"))
    (prompt "\nOffset distance or through" )
    (setq dist (getdist))
    (if (or (= dist nil)(= dist ""))
    (setq dist last)
    (setq obj (entsel "\nSelect object to offset:"))
    (setq pick_pt (car(cdr obj)))
    (setq ent (car obj))
    (setq side_pt (getpoint "\nside to offset"))
    (command "offset" dist pick_pt side_pt "")
    (setq ent1 (entlast))
    (setq ptlst (entget ent1)
    b (assoc 8 ptlst)
    c (cons 8 c_layer)
    d (subst c b ptlst))
    (entmod d)
    Last edited by Dan5; 26th May 2008 at 05:27 pm. Reason: um, emoticon appearing in my code...
    Junior Member
    AutoCAD 2004
    May 2008
    17
    two subjects below your post is advanced offset. Does exactly what you're looking for & more.
    http://www.cadtutor.net/forum/showthread.php?t=23277
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Not sure what section of code you want to repeat, guessed it was picking other objects to offset once:
    Code:
    (defun c:otl ()
           (setq dist last)
       (while  ;; ** while loop to repeat until user hits 'enter' (nil)
                b (assoc 8 ptlst)
                c (cons 8 c_layer)
          (entmod d)
       );; **end of while loop
  1. Loading LISP Commands
    By samanisc in forum AutoCAD General
    Last Post: 21st Aug 2007, 02:12 pm
  2. **HELP**me with my commands
    By Paul Davis in forum AutoCAD General
    Last Post: 6th Aug 2007, 03:15 pm
  3. Undo multiple commands in lisp as one
    By gman in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2006, 05:57 pm
  4. Lisp for a sequence of commands...
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Feb 2006, 08:30 pm
  5. Commands
    By DPATTERSON23 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2005, 11:14 pm
