Results 1 to 5 of 5
    Junior Member BDIZZEL124's Avatar
    Revit 2008
    Apr 2008
    Jacksonville, FL
    24
    Question Converting a .iam file in to a .dwg
    Im pretty burnt out on Autodesk programs right now, I have been under going turtiurals for MEP 2009 (these can be not fun) and a client recently did a project in Soild Works and sent me the .ISG file. I converted that file to a .iam. In the Help Topics for inventor I found how to convert the file but when i do it nothing shows up in AutoCAD model/paper space. I did change the options in the save a copy as dialog box. Dose any one have any solutions to my problem.
    Thanks,
    Brian
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Zip and attach the original .isg (or is it .igs) file here.
    Assuming you did get the solids you could go to Applications>AEC Exchange and select Save as DWG Solids.
    or
    you could Save Copy As *.sat and use the acisin command in AutoCAD.
    How much training have you had in using this software?
    Revit 2008
    Apr 2008
    Jacksonville, FL
    24
    I have little knowledege of this program. I tried AEC Exchange and the program keeps shutting down. Im attempting to do the save as.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    What release of Inventor are you using?
    Have you installed all Hot Fixes and Service Packs. (particularly if using r2008 have you replaced the AOEMViewer?
    Inventor is a professional program and requires a professional level of prepartion. I would look for training.
  5. #5
    Revit 2008
    Apr 2008
    Jacksonville, FL
    24
    143 MB (150,552,576 bytes)
    I have it in CAD but the file size is shown above are to big. How can i reduce the file size?
    I used the purge command and the size did not reduce.
  1. Converting a later dwg file to 2000
    By New2CADmike in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2008, 02:19 pm
  2. Converting CAD file into powerpoint file like video file
    By rattaka in forum AutoCAD Beginners' Area
    Last Post: 2nd Sep 2007, 05:46 pm
  3. Converting CAD file into Word file
    By Ulqin in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2007, 02:56 am
  4. PDF file, scaling from, converting from?
    By Angora*ribbon in forum AutoCAD Beginners' Area
    Last Post: 10th May 2007, 02:35 pm
  5. Method of converting LSP+DCL files to EXE file?
    By youngken in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Jun 2005, 05:59 am
