Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Break Lisp
    Senior Member neekcotrack's Avatar
    MEP 2009
    May 2008
    Florida
    329
    Exclamation Break Lisp
    Does anyone know of a lisp that breaks at line:
    1. If you click the line you want to break.
    2. Then click the line you want it to break with.
    3. It breaks the line on both sides evenly depending on the dimscale what the distance of how far.
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    Code:
    ;;;=======================[ BreakObjects.lsp ]==============================
    ;;; Author: Copyright© 2006-2008 Charles Alan Butler
    ;;; Contact @  www.TheSwamp.org
    ;;; Version:  1.8 Mar. 13,2008
    ;;; Purpose: Break All selected objects
    ;;;    permitted objects are lines, lwplines, plines, splines,
    ;;;    ellipse, circles & arcs
    ;;;  Function  c:MyBreak -       DCL for selecting the routines
    ;;;  Function  c:BreakAll -      Break all objects selected with each other
    ;;;  Function  c:BreakwObject  - Break many objects with a single object
    ;;;  Function  c:BreakObject -   Break a single object with other objects
    ;;;  Function  c:BreakWith -     Break selected objects with other selected objects
    ;;;  Function  c:BreakTouching - Break objects touching selected objects
    ;;;  Function  c:BreakSelected - Break selected objects with any objects that touch it
    ;;;  Function  break_with  - main break function called by all others and
    ;;;                          returns a list of new enames, see c:BreakAll
    ;;;                          for an example of using the return list
    ;;; Requirements: objects must have the same z-value
    ;;; Restrictions: Does not Break objects on locked layers
    ;;; Returns:  none
    ;;; Revision 1.8 Added Option for Break Gap greater than zero
    MEP 2009
    May 2008
    Florida
    329
    so will this break a one of two lines intersecting on both side and make the line line 2 units from the line it was intersecting with and changes the 2 units if the dimscale changes?
    MEP 2009
    May 2008
    Florida
    329
    Where do I find the breakobjects lisp?
  5. #5
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    Quote Originally Posted by neekcotrack View Post
    Does not have anything to do with DimScale.
    You select the GAP size you want. The routine has a variety of options for selections to break & break with.
    The latest version is found here.
    http://www.theswamp.org/index.php?to...7166#msg277166
    You must be a forum member to use this link.
  6. #6
    Full Member
    AutoCAD 2008
    Feb 2008
    53
    Perhaps this is something to get you started:
    Code:
    (defun c:BM( / L1 P1 P2)
      (defun *error* (MSG) ; local error handler to reset entity redraw
        (princ (strcat "\n" MSG))  ; return the error message
        (if osm (setvar "osmode" osm))
       (setq osm (getvar "osmode"))
       (Setq L1 (entsel "\nSelect object to break: "))
       (while L1 (progn
                    (Setq P1 (getpoint "\nChoose break point: "))
                    (command "BREAK" L1 "F" P1 "@")
            (setq L1 (entsel "\nSelect next object to break, or ENTER: "))
                 );end progn
       );end while
    )  ;end defun
  7. #7
    MEP 2009
    May 2008
    Florida
    329
    Thanks for everything.
  8. #8
    MEP 2009
    May 2008
    Florida
    329
    The breakwith.lsp is what I am looking for sept for a one things.
    1. I want it to automatically set the break gap to (2 times (getvar "dimscale"))
    If anyone can help me I am thanking you in advance!
  9. #9
    AutoCAD 2000
    May 2004
    Tampa, Florida
    805
    Make sure the BreakObject lisp is loaded & use this;
    Code:
    (defun c:BreakWithMyGap (/ cmd ss1 ss2 tmp)
      (command "_.undo" "_begin")
      (setq cmd (getvar "CMDECHO"))
      (setvar "CMDECHO" 0)
      (setq Bgap (* 2.0 (getvar "dimscale")))
      ;;  get objects to break
      (prompt "\nBreak selected objects with other selected objects.")
      (prompt "\nSelect object(s) to break & press enter: ")
      (if (and (setq ss1 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
               (not (ssredraw ss1 3))
               (not (prompt "\n***  Select object(s) to break with & press enter:  ***"))
               (setq ss2 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
               (not (ssredraw ss1 4))
        (break_with ss1 ss2 nil Bgap) ; ss1break ss2breakwith (flag nil = not to break with self)
      (setvar "CMDECHO" cmd)
      (command "_.undo" "_end")
    MEP 2009
    May 2008
    Florida
    329
    do I just put this in with the breakobjects lisp
  1. Break Line Lisp
    By neekcotrack in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th May 2015, 06:36 am
  2. custom break or break settings
    By b.muqlueen in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Apr 2008, 05:46 pm
  3. custom break or break settings
    Last Post: 2nd Apr 2008, 01:19 pm
  4. Break at Point
    By Rooster in forum AutoCAD Drawing Management & Output
    Last Post: 11th Feb 2006, 02:19 am
