Results 1 to 8 of 8
    Full Member hellnback's Avatar
    Civil 3D 2012
    Mar 2008
    New Zealand
    80
    Default Trouble Selecting Hatches
    Hi all,
    I have a drawing (map of a farm) and each of the paddocks contain a solid hatch, these are on various layers (eg. grazing, scrub). Anyway, my problem is trying to select these hatches, I use MATCHPROP but then have trouble select the source hatch then also have problems selecting the target (even using crossing).
    It seems that I have to click right on the hatch origin for it to work, which can be tricky with a complex hatch boundary.
    So is there a way/variable to change the way hatches are selected.
    Cheers, Brad.
    60% of the time it works everytime.
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Dunno if this will help. It's from the FAQ.....
    http://www.cadtutor.net/faq/question...+to+a+Hatch%3F
    Civil 3D 2012
    Mar 2008
    New Zealand
    80
    Thanks Alan, but alas.... it didn't help.
    Full Member Arch_Eric's Avatar
    ADT 2006
    May 2008
    Texas
    25
    If you find a way, please let me know.
  5. #5
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,210
    If the proplem is overlapping objects, use Ctrl+Shift and left click to cycle through the objects until the hatch is highlighted.
    Rob
  6. #6
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    I know this can be a bit of a wild 1 with complex shapes, but try aiming for the middle of the hatch.
    Select the hatch first and make a mental note of where the grip is, and then when you are trying to matchprop aim for the middle and you should pick it up.
  7. #7
    Map 3D 2009
    Jun 2006
    4,181
    Or you can do what I do....move the mouse cursor all around until you get a response. Then go for it.....
  8. #8
    Civil 3D 2012
    Mar 2008
    New Zealand
    80
    Quote Originally Posted by Alan Cullen View Post
    Yes, that seems the best way.... (and adds to my left click RSI!!)
  1. If were talking about hatches
    By steepcreeker in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2008, 11:44 pm
  2. missing hatches
    By halfcracked in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 03:52 pm
  3. Creating Hatches
    By mattwsp in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jun 2006, 04:22 pm
  4. Help with roof hatches!!!
    By Caiti in forum Blocks, Images, Models & Materials
    Last Post: 6th Jun 2006, 04:35 pm
  5. How do I Separate hatches?
    By Ikarikun in forum AutoCAD General
    Last Post: 4th Dec 2005, 07:37 am
