1. "All linetypes of entities should be set to be BYLAYER." That should be the first line in your standard on linetypes.
Would it be possible to create some kind of script to search through all layers in a DWG and change for example all 'Center' linetypes to 'Center2', and all 'Dashed' to 'Dashed2' etc?
Also could it be cleverer and search within a linetypes name so it could pick up these linetypes is they're from an XREF & beginning with eg 'XREF1Center' and changing it to 'Center'
Also, anyone fancy writing a script for this?
Currently we don't have any decent standards in our company, I'm in no position to create any so am trying to find a quick fix rather than changing everything manually to make linetypes display correctly.
Using AutoCAD2012, Civil 3D 2012, 3DS Max 2012, AutoCAD MEP 2011, Imagemodeler 2009, Zbrush, Solidworks, PTGui, Photomatix, Photoshop
PORTFOLIO: http://www.flickr.com/photos/47676682@N04/
Life's constantly changing - keep up or get left behind
LCE - Yeah that would be great!
NBC - Yes you're right, Currently I'm receiving drawings from contractors, surveyors, colleauges. Some are good, some are crap! Some drawings contain a mixture of imperial & metric linetypes, some a scaled by overiding the entity in properties. Also some of my superiors may find it a bit arrogant of me to try and start telling them how they should be doing their drawings as I was only promoted from a junior last month, even though some of their drawings really suck!
I want to be able to quickly, set all linetypes to by layer, and linetype scale 1, and then change all of them to use the default linetypes which end with number 2. This is because the linetypes that don't end with 2, eg 'center' look far too big when used with linetypes containing text.
Luckily, both the imperial & metric .lin files contain identical linetype names so the relevant one can be loaded easily and if linetypes are included in a drawing that arn't written in both the metric & imoperial .lin files, then I can just load the other .lin file and change the Global Linetype Scale.
Hope that makes sense!
See attached.
Let me know if you need any help with this.
Hello mate, how do I load that? I had someone have go who's had some experience with writing VBA but no luck so far.
Cheers
Dave
Just made 1 little change.
To load it type -vbarun at the command line and then
"filepath\ltset.dvb!Start"
Where filepath is the location of the ltset.dvb
Let me know if you need any more help with this.
Hi
I've got this working but in the existing lt dropdown it contains all the linetypes from the .lin file that the drawing is using, even though I've purged out all the linetypes not needed. This would involve changing a silly number of linetypes when it's not needed.
Thanks for trying though
Dave
*EDIT*
I think these linetypes are being loaded from my XREFs, also is there a way to change the second dropdown to display only the linetypes in my .lin file, rather than having all the ones nested in the XREFs as well?
Great, thanks, don't suppose there's any way to do a search within VBA? So any linetype containing 'center' could be picked up automatically?
Eg "XREF12314144linetypecenter"
No sweat if it's not possible!
