Results 1 to 5 of 5
    Full Member erik_NL's Avatar
    AutoCAD 2007
    Jan 2008
    NL
    57
    Default Overkilll against vba cleaning
    yesterday did some cleaning with overkill ( Express Tools ). Started at 10.00 in the morning and at circa 16.30 i wend home. Does everybody has this problem ?
    i'm making a vba to clean drawings which are original maked by a apple cad program ( couldn't get more information ) en these have a lot of blocks ( i can explode thes in vba, that's cleared ) but also a LOT of double lines so i think; run overkill but as this take so much time a drawing it ain't nice anymore.
    Anybode has a vba solution that can compete with overkill and doesn't take as much time ?
    Super Member Hedgehog's Avatar
    Hedgehog's Computer Details
    XP sp 3
    Asus NCL-DE/1U E7520
    2 x Intel Xeon 7150N
    8 x Kingston KHX6400D2K2/4G 4 GB PC2-6400
    NVidia Quadro FX 5500 1 GB Pci-X 16
    2 x Seagte Barracuda 7200.10 320 GB HDD
    ViewSonic VP2290b-2Black 22” LCD
    MEP 2009
    Aug 2007
    Any Pub, Derbyshire, UK
    896
    OVERKILL is best used on smaller collections of around 10,000 entities. 50,000 entities will normally take a couple of mins etc etc... so if you can devide the task into sections of your drawing then you'll cut the time considerably (& if you think about it comparing one side of a massive drawing against the other is fairly pointless).
    In the past I've also used a lisp called DUPREM.lsp (you can find it on google) but it's not as comprehensive.
    Only the lonely only ... PhotoGallery / Music
    AutoCAD 2007
    Jan 2008
    NL
    57
    Quote Originally Posted by Hedgehog View Post
    ah, i will test duprem.lsp. I'm now running a testdrive with 10 drawings, whit my cleanup vba program. But even this takes so long ( about 10 tot 15 minutes a drawing ) with no special commands. I can't find why this drawings are so work intensive. I ( and collegues ) tried a lot of things, on different computers/setups but it really takes to long and we do have about 45 floors with updates on regular base.
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Quote Originally Posted by erik_NL View Post
    .......Started at 10.00 in the morning and at circa 16.30 i wend home. Does everybody has this problem ?
    Yeah, don't think that's a problem though - you're lucky, i start at 9:00 and go home at 18:00, lol
    Cheers,
    PaulRenegade @ hardwiredstudios..
    XP Pro / AutoCAD 2007 : Pentium Core 2 Q6600 Quad Core : ASUS P5N-E SLI Motherboard : 4GB DDR2 RAM : 2 x SLI NVIDIA 8500GT SLi 1024MB DDR2 PCI-Express Graphics Cards
  5. #5
    AutoCAD 2007
    Jan 2008
    NL
    57
    Quote Originally Posted by hardwired View Post
    No, you'r lucky.
    I start at 08.00
    ( overkill on the other hand ... )
    i have started a other thread for the overall problem.
    vba cleaning drawing with vba.
  1. Cleaning Up a DWG
    By chris81 in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2012, 10:55 pm
  2. cleaning a drawing of invisible items
    By davidg47 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Apr 2008, 11:27 am
  3. Cleaning multiple corners
    By edortizr6 in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2007, 01:26 pm
  4. Cleaning Up Zoom Extents
    By wherestheanykey in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2007, 03:29 pm
  5. Cleaning lines...
    By JimJ in forum AutoCAD General
    Last Post: 14th Jun 2006, 07:52 pm
