Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    AutoCAD 2013
    Nov 2011
    5,986
    Quote Originally Posted by Jenghode View Post
    this problem :
    is solvable with this way :
    i've tried it and done well
    Baiklah. Seharusnya ngerti perbedaan visualstyle dari perspective, kelihatannya dari posisinya.
  2. #12
    Forum Newbie Jenghode's Avatar
    Jenghode's Computer Details
    Win XP
    Gygabyte
    1Gb
    230
    230
    Acer 18"
    Construction
    Jenghode's Discipline Details
    Accountant
    Construction
    AutoCAD 2007
    Mar 2012
    Indonesia
    3
    Quote Originally Posted by Dadgad View Post
    asem..... orang indo rupanya. wakakkaka. how r u? and tinggal dimana?
  3. #13
    AutoCAD 2013
    Nov 2011
    5,986
    Nggak, bojog saja, tapi lumayan lancar. Selamat datang di forumnya. Latihan terus supaya lebih cepat pintar.
    Sing ada apa de di Bali.
    ..... and now we return to our regular programming.
  4. #14
    Forum Newbie
    Mechanical
    AutoCAD 2016
    Jul 2017
    1
    Quote Originally Posted by beauXjames View Post
    As this method is correct, it doesn't really help understand what's going on. In essence, AutoCAD is always capable of 3D, so the 'mode' isn't about going back and forth from 2D to 3D, but simply modifying how you view the infinite or finite boundaries of CADspace.
    If you are wanting to get back to the default drawing view, you need to change your perspective. To change perspectives, use your view tool. Simply type 'view'. The view manager opens. Expand the 'Preset Views'. Select 'Top' and press 'OK'. This puts you back to the default drawing perspective.
    If you're looking at grey space and not the traditional black, then the visual style is not the default 2d style...to change this back, do the following:
    type 'vscurrent' or open the visual styles toolbar
    select 2dwireframe
    and, in a nutshell, that'll get you back to the basics and, hopefully, give you a little insight on how things are set up in this application
    Thank you very much james.
    I know this is a very old thread but I registered to this site just to thank.
  1. How do I switch between viewports?
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 5th Feb 2008, 08:18 am
  2. Switch Detail
    By CADken in forum SketchUp
    Last Post: 30th Jan 2008, 11:08 pm
  3. On/Off switch
    By midikairali in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jan 2007, 06:40 am
  4. How do I switch MDT or ADT to Autocad ?
    By Rangerbob in forum Tutorials & Tips'n'Tricks
    Last Post: 26th Sep 2006, 08:37 pm
  5. switch between dwgs
    By SteelDet in forum AutoCAD Beginners' Area
    Last Post: 5th Jun 2006, 07:13 pm
