Results 1 to 2 of 2
    Senior Member
    AutoCAD 2004
    Apr 2006
    235
    Default Full/Relative Paths and the ability to edit
    I'm not sure if it's just my machine, my program, or what, but I've noticed a very peculiar situation when it comes to editing X-refs in place (as opposed to opening the xref dwg itself):
    When an XR is attached with a relative path, 99% of the time I go to edit it in place I receive the following:
    Code:
    ** 1 object removed from selection set.
    ** AcDbOle2Frame objects cannot be edited in place.
    Errors found in references to other objects:
    ** AcDbOle2Frame objects cannot be referenced.
    and am unable to edit the xref unless I open the .dwg itself.
    This hardly ever happens when the XR is attached with a full path. I'm not saying it doesn't occur once in a blue moon, but it's almost gauranteed that if it's a relative path, it's going to be a hassle about a quick edit.
    Is there something I don't know about here? I've tried it on the different machines, and it seems to be a consistent thing. We're using ACAD '07.
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
    Forum Newbie
    AutoCAD 2008
    Nov 2008
    1
    Smile Ole
    Hello slimjramirez,
    I had the same problem and same error message.
    To sort out the problem I have selected 'Prompt to select nested objects' radio button in the Reference Edit window that pops up.
    This way I was able to select Xref file partailly to eliminate parts that did not give error message when selewcted to finally find the part giving error message.
    In the end I have found that there was an OLE object (Picture) that was copied-pasted that was not referenced correctly as the file it was created from was moved somewhere else or deleted.
    To do the same thing you need to identify an OLE object by the same method. Best way to do this is by first selecting half and then finding half part giving error and then going in halves continually till you locate the object giving error.
    Hope this helps.
    Cheers
    Cuneyt
  1. ability to transfer routines
    By td88 in forum AutoCAD Beginners' Area
    Last Post: 7th Apr 2008, 01:34 pm
  2. Block Attribute answers ability to change block Physical Attributes??
    By Kaidoz in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Mar 2008, 10:25 pm
  3. BATCH CHANGE FULL PATH TO RELATIVE PATH
    By beth in forum AutoCAD General
    Last Post: 21st Jun 2006, 02:38 am
  4. How to draw Rectangle: Center-Full Base-Full Height?
    By LihtiumOverdosE in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Oct 2005, 07:00 pm
  5. relative offset
    By droseman in forum AutoCAD General
    Last Post: 15th Aug 2005, 05:34 pm
