Results 1 to 10 of 10
    Junior Member
    not specified
    Oct 2004
    NY
    21
    Default Insert Excel file to Cad
    Hi all,
    I have problem inserting Excel file to Cad.
    After I insert a file from Excel to Cad, I am not getting the hole page.
    9 columns I can get to my Cad file only .
    What I should do to solve this problem ?
    Please if anyone can help.
    thanks
    marcus
    I have had the same problem.. there is alimit to how big the fiel can be. At least in 2000i this is what the help file says:
    Issue
    You paste a Microsoft Excel spreadsheet into AutoCAD, however, the spreadsheet is truncated.
    Solution
    When an Excel spreadsheet is pasted into AutoCAD, only the Picture (metafile) format is used, which can result in the spreadsheet being truncated. This normally occurs when the column width and row height in Excel are set to the default (default width is 8.43, and default height is 12.75), and the pasted object exceeds 18 columns and 70 rows.
    Use one or both of these methods to resolve the problem:
    Method #1
    In Excel, reduce the column width and row height. You can paste more of the spreadsheet if you reduce the column width and row height.
    Method #2
    Paste the spreadsheet in separate parts. By pasting the spreadsheet in separate parts you can break it down into several smaller OLE objects.
    Junior Member
    not specified
    Oct 2004
    NY
    21
    Thank you Marcus,
    marcus
    Default EXCEL
    NO PROBLEM.
  5. #5
    Senior Member erona's Avatar
    AutoCAD 2007
    Feb 2005
    Philippines
    306
    erona
    "AutoCAD habangbuhay" not anymore... moved to Vectorworks>Cinema4D
    Just got back to AutoCAD. Modeling directly in C4D.
  6. #6
    Junior Member
    not specified
    Oct 2004
    NY
    21
    Thank you Erona,
  7. #7
    jorlwebb
    Default Too Late for me
    Aww, I was gonna guess that solution. I don't know CAD, yet, but I'm familiar with Excel and how it plays with others (i.e., that's typical Excel) Hah, but I'm too late.
  8. #8
    Full Member
    AutoCAD 2007
    Jul 2009
    30
    HI erona, seems your filipino, your good in autocadd
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    What version of AutoCAD are you using? In the past inserting an OLE object was about all one could do without resorting to third-party software. With newer releases of AutoCAD (2008 and higher) one can use DataLinking. Note: the large the Excel file size the more difficult it becomes to do this successfully. Nine columns (how many rows?) doesn't sound unreasonable.
  10. #10
    Full Member
    AutoCAD 2007
    Jul 2009
    30
    Default Cinema4D, & vector
    Quote Originally Posted by erona View Post
    Im planning to go on vacation in philippines, where we can have a crash course for that Cinema4D and vector,
    Im also a Filipino!
