not so simple an answer...
to do what you want the horizontal lines will have to shrink/enlarge in order to maintain the angle...i don't think chaining actions will do...i beleive you will need 1 linear parameter, for the height, and then 4 stretch parameter for each coner using distance multipliers and angle offset values...
the distance multiplier will probably be 2.9986/3 (3 is the lenght of your angle line) as the angle line is longer the vertical dimension so it need to grow/shrink a % value...
just to get you going, i set-up the top-left corner so look at the parameter values and reverse engineer from there...
