Results 1 to 5 of 5
Thread: XRef doubt
    Full Member myself's Avatar
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    Default XRef doubt
    Hello there,
    i've just figured out that when you call a drawing as reference and then later you change something in the original one, that makes no effect in the drawing where is being used as reference, i mean... autocad only updates the geometry but not the proprieties of each object, which can be really annoying because i need to change a linetype and now i must go to each drawing with that reference, i thought that after changing the original drawing there would be way to update those that had that drawing as reference.
    thnaks in advanced for our answeres guys
    Super Member
    Architecture 2009
    Apr 2008
    London, (sunny UK)
    686
    look into your VISRETAIN settings.
    See the help file for info about VISRETAIN.
    Senior Member Teeds's Avatar
    AutoCAD 2009
    May 2005
    427 miles ENE of Orla Texas
    141
    I'm confused.
    I make changes all the time to base models that show up in my files that Xref the file.
    Are you attaching the file or inserting the file?
    If you are attaching an Xref it should always go reload the latest version of the reference file.
    Tony Eeds aka Teeds aka Dad aka Grandpa
    Proud member of the Peanut Gallery and the Pajama Economy
    AutoCAD 2007 - 2008 arrived, and I just got an email that 2009 has shipped
    Quote Originally Posted by Teeds
    Without training, CAD is not drafting ... it only makes you draw bad faster
    AutoCAD 2009
    May 2005
    141
    Quote Originally Posted by LCE View Post
    I didn't think about that variable.
  5. #5
    AutoCAD 2009
    Jun 2008
    Portugal - Porto
    97
    thank you guys, i havent tried that yet, im a little busy with some other stuff, although the problem was related with a linetype, i had changed the linetype and the ltscale on my original drawing but that wasnt updated on my final drawing, it might have been because some of the lines were DGN(MIcrostation).
    im gonna look for some of the best tips to work with references, i think i know quite enough however its always good to know more since im gonna need very often.
  1. XREF in VB
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2008, 07:19 pm
  2. Constraints doubt
    By ____________ in forum Autodesk Inventor
    Last Post: 19th Apr 2008, 11:30 pm
  3. Layer states don't transfer from an Xref of an Xref....
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 06:02 pm
  4. Xref
    By ebjco in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2006, 03:12 pm
  5. export doubt
    By skiter in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2005, 08:04 pm
