Rhayes Posted June 16, 2008 Share Posted June 16, 2008 I have AA-2008 Can you convert Microstation drawings to ACAD Quote Link to comment Share on other sites More sharing options...
LCE Posted June 16, 2008 Share Posted June 16, 2008 Which version of dgn? Quote Link to comment Share on other sites More sharing options...
Rhayes Posted June 16, 2008 Author Share Posted June 16, 2008 Not Sure of the Version.? Does that make a big Difference?? Quote Link to comment Share on other sites More sharing options...
JerryG Posted June 16, 2008 Share Posted June 16, 2008 Try these http://www.cadtutor.net/forum/showthread.php?t=5059 http://www.geocities.com/junglejimy/QnApg27.html Hope that helps! Quote Link to comment Share on other sites More sharing options...
Rhayes Posted June 30, 2008 Author Share Posted June 30, 2008 I only have about 6 drawings that I need converted from DGN to DWG I do not wat to buy a package to do a one time conversion. Are there any other ways to convert a DGN to DWG.??? and I do not know the DGN version.? Only know it's not V8 because AA-2008 can not import it.... Thanks.. Quote Link to comment Share on other sites More sharing options...
chulse Posted June 30, 2008 Share Posted June 30, 2008 AutoCAD Map can import V7 DGN files... Quote Link to comment Share on other sites More sharing options...
chulse Posted June 30, 2008 Share Posted June 30, 2008 Probably best to ask the source to export them to DWG for you... Be aware however of units and ucs going haywire, strange things can happen... Quote Link to comment Share on other sites More sharing options...
drwhite Posted July 13, 2010 Share Posted July 13, 2010 Problem: Using AutoCAD Mechanical 2010. Could import dgn file and see dimensions and text. Could not see the text "fractions", but could see dimension fractions. Got to messing with the fontalt, fontmap, and added some of the dgn shx shapes to the acad.fmp file and substituted simplex.shx for those. NOW, I cannot see any text, or any dimensions. In addition, level 1 comes in "off". Turning it on does nothing relative to showing text. What did I screw up? Went back and edited the dgn shx files out of the fmp file, still no text showing. Help! Quote Link to comment Share on other sites More sharing options...
