Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2000i
    Jun 2008
    2
    Default "Freeze in current viewport" does not work...
    I cannot seem to get the "Frozen in current viewport" to work. I have the drawing in the model, I went to the layout1 page and added a viewport. I positioned the part of the drawing in the viewport and then selected the viewport. After that, I went to the format menu and slected layers. I clicked the icon to make a snowflake appear under the column 'Current VP Freeze'. I clicked ok and the layers that were supposedly frozen didn't go away. Aren't they supposed to not be visible?
    The status bar shows i'm in paper mode. I'm using Autocad 2000i. I did some searching on google and these forums, but I cannot find a solution.
    Thanks for any help.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    You should be in model space, dbl-clk inside the viewport to make it active and try again.
    Forum Newbie
    AutoCAD 2000i
    Jun 2008
    2
    Default that's it!
    perfect! that was it. Thanks a ton!
  1. "Nearest" snap mode doesn't work in 3D
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 19th Mar 2007, 11:44 pm
  2. "Freeze Layer" tool
    By slg321 in forum AutoCAD General
    Last Post: 12th Feb 2007, 07:21 pm
  3. "Extension" with arcs,and can't make it work.
    By Astucia in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jun 2006, 11:13 pm
  4. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
