Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Default Create surface to 3d solid?
    How can i convert a 2d surface two a 3d solid object so a can later use it as a slicing reference so i can subtract part of an object?
    So lets say i have a sequence of lines that at some point close and make some kind of 3d region.I want to convert that to a solid object so i can cut parts of 3d objects.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    A region can be extruded as a solid.
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    2d surface? The word surface implies a 3 dimensional object in most cases. Maybe you could explain in further detail what you're doing?
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Surfaces can be used to Slice a solid - you do not need to convert the surface (assuming you are using the r2007 or later surfaces tools) to a solid.
    But if you want to convert the surfaces to solids use the Thicken command.
    I suggest you go through the tutorials in my signature.
  5. #5
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Quote Originally Posted by rustysilo View Post
    Not always.It can be a rectangular surface for example,with same (or no -zero-) elevation,which doesn't make it 3 dimensional.
    Anyway for example if you look at the picture i have some kind of a surface.Its a closed polyline which I've converted to a region,and i want to subtract the upper part of the solid.From the point it intersects with my custom plane and above.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by therock005 View Post
    And in fact, AutoCAD 2007 and later has a tool to create a planar or trimmed planar surface.
  7. #7
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    Hi man,well I've noticed that option,but i don't always want to make planar surfaces,some times i need to create more complicated ones,and even with the planar surface the subtract doesn't work.I select subtract,i then select the surface and the solid or tried the other way around,and it doesn't seem to remove it.
    EDIT:On my example if i select the solid and then the polyline region i get
    At least two solids or coplanar regions must be selected.
    If i on the other hand,select the planar object i get No solids or regions selected,and if i aply thickness i get to subtract the part,but i dont want to apply any thickness in order to subtract.
  8. #8
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    What can I say, I've been stuck in civil a while where surface generally means terrain surface = 3d.
    flickr |
    work | blog | creed
  9. #9
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    ...and even with the planar surface the subtract doesn't work.I select subtract,...
    You had it right in your original post, Slice not subtract.
    ...How can i convert a 2d surface two a 3d solid object so a can later use it as a slicing reference ,...
    Do the tutorials in my signature. You can use a curvy surface to Slice (subtract, sculpt, whatever you want to call it) away unwanted material from your solid.
  10. #10
    Senior Member
    AutoCAD 2007
    Dec 2006
    235
    I tried it but i had no luck.I selected slice,then highlighted the solid,then surface and i tried selecting the object i have but the slice was not succesful.
    Here's what I'm currently trying.
    I tried the convert to solid and convert to surface options as well,but i got the message "object could not be converted"
    It's in the x-ray mode so you can notice the objects better.The yellow one is my solid its a 3d cubicle,and i want to removethe object i've placed on the corner so it will acquire the shape i want it to.
  1. Help to create surface
    By kama1005 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Jun 2010, 11:34 pm
  2. intersection between solid and surface
    By mirco in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Sep 2008, 12:27 pm
  3. how do I create a non-planar surface?
    By gib65 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Jan 2008, 04:48 pm
  4. surface into a solid object.
    By Gemma Elizabeth in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jan 2008, 01:57 am
  5. Surface into Solid??
    By DrafterX in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Aug 2005, 09:25 am
