Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Junior Member
    AutoCAD 2008
    Nov 2007
    11
    Default 3d curved surface
    I was wonder how to create a 3d curved surface (ex. a 90 degree pipe bend)
    Thanks in advance, Mfranke
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Draw a polyline representing the centerline of your pipe. Draw a circle at the diameter of the pipe. Use the sweep command and use the circle as the object to sweep and the centerline as the path.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    You might want to go through the tutorials in my signature.
    Senior Member CADguy209's Avatar
    AutoCAD 2013
    May 2008
    Stockton, CA
    110
    You could also draw a spline representing the center of your pipe with the bend, draw your circle and extrude the circle using the path option. The path being the spline/center line of your pipe.
  5. #5
    Super Member papagyi's Avatar
    papagyi's Computer Details
    window vista (home premium)
    AutoCAD 2009
    Apr 2008
    Myanmar
    518
    Drawing
    Quote Originally Posted by CADguy209 View Post
    This method can give solid entity.
  6. #6
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    u could also use loft to achieve that
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    I would use Sweep.
  8. #8
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    sweep or extrude along a path is the way i would go, if you want an actual pipe then simply draw two circles one for the outer dia and one for the bore, then subtract the inner one to give you tube,
  9. #9
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by yedan View Post
    ... simply draw two circles one for the outer dia and one for the bore, then subtract the inner one to give you tube,
    Too much work. Sweep region. Can be used over and over again. Create a library of commonly used sizes.
  10. #10
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    Quote Originally Posted by JD Mather View Post
    making a library is a good idea but you must first do the work to have something to make the library from.
  1. Draw Text on a Curved Surface
    By tlawson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Sep 2008, 09:39 am
  2. bitmap on a curved surface
    By Mike Kruger in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2008, 10:03 am
  3. Curved text?
    By AutoNewbie in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Apr 2008, 10:46 pm
  4. Making a curved surface
    By amber in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Dec 2006, 04:19 am
  5. Curved sides
    By marinebro0306 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Aug 2006, 09:10 am
