Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Super Member nocturne00's Avatar
    nocturne00's Computer Details
    Windows Vista SP2
    Dell Studio XPS
    Intel(R) Core(TM)2 Duo CPU P8600
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    Default Xref In Greyscale
    Hi guys;
    Im working on drawings which basically rely on xref for ease of work in terms of it always being updated; eg road layouts, pipe layouts, Land Topo.
    on presentation of development plan drawings there are certain portions that needs to be in greyscale to put emphasis on an xref whose lines are at 100% screening. vice versa for the other xrefs in terms of emphasis for other sheets.
    Is there a way to present in greyscale entire xrefs without changing the colors of the layers in the xref itself?
    the only solution i do is to make a separate xref drawing of road, pipe layout and structure which is entirely on a single color i setup on 80% screening; so noob ^_^
    there is a way I browsed in the forums but it uses autolisp.
    I just wanted to know if autolisp is the only way to make this happen
    TIA
    Senior Member
    Architecture 2011
    Jan 2008
    100
    Default Style Based Plotting
    Have you looked at style based plotting rather than color based?
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    If the color of the entities in the xref are 'bylayer'...
    Layer Manager > use the tree to filter the xref layers
    Select all the xref layers (Ctlr+A)
    Change the color to grey.
    If you want the colors to remain grey, set Visretain =1
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    i dont really use STB, im more on the CTB.
    Great help seifer; thanks for the help. it saves me a lot of time instead of making new greyscaled xrefs...^_^
    I thought of this method once but never tried it thinking that when i reload the xref, all colors will revert to its original
    but I really thought there was a command for this ^_^
    Thanks again
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    This should work in most cases... change the "9" to what color you want
    Code:
    (command "-layer" "c" "9" "*|*" "")
  6. #6
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    678
    take a look at that variable
    VISRETAIN
    this system variable controls the properties of xref-dependent layers
    0 ) Dont save the layer properties
    1 ) Save the layer properties
  7. #7
    Windows Vista SP2
    Dell Studio XPS
    4GB DDR3 RAM
    ATI Radeon, 512MB
    22" Samsung
    AutoCAD 2009
    Jun 2008
    Tartarus
    769
    not exactly what I was lookin for,
    I already use visretain, visretain is concerned with saving or not saving any changes made to xref layers.
    the previuos post is what im currently using to manipulate greyscaling of the xref.
    ....always perform Beyond what is expected.
  8. #8
    Forum Newbie
    Architectural
    AutoCAD 2014
    May 2017
    5
    I also found that the viewport "properties" affects plot style.
    I had views set to 2DWIREFRAME but VP plot style was set to SHADED and it wouldn't plot in gray scale or monochrome until I set it to WIREFRAME.
  9. #9
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    Dude I know your kinda new but the thread is nearly 10 years old. I think he figured it out by now.
  10. #10
    Forum Newbie
    Architectural
    AutoCAD 2014
    May 2017
    5
    So you're saying that no one else has had or will have that problem again?
    And it's “you're"
  1. Xref Help
    By ashllliey in forum AutoCAD General
    Last Post: 26th May 2008, 08:52 am
  2. Xref Help
    By BDIZZEL124 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Apr 2008, 08:12 pm
  3. Xref Help
    By studiorat in forum AutoCAD General
    Last Post: 11th Jan 2008, 09:55 pm
  4. xref
    By cadprog in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Nov 2007, 08:34 am
  5. Layer states don't transfer from an Xref of an Xref....
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 06:02 pm
