MikeP Posted June 23, 2008 Share Posted June 23, 2008 Im Trying To Find A Lisp Where I Can Take A 3d Object We Use Cabinets, And Create An Exploded View Of It. Here Is A Before And After View Quote Link to comment Share on other sites More sharing options...
rocheey Posted June 23, 2008 Share Posted June 23, 2008 well, if there is lisp out there to explode an assembly of solids, it is doubtful it will run as you've drawn - since the lisp won't know about what a cabinet is, the sides of the middle cabinet will 'explode' into each side of the end cabinets. Thats why I only explode one cabinet at a time. What software are you using for your cabinets? Quote Link to comment Share on other sites More sharing options...
MikeP Posted June 23, 2008 Author Share Posted June 23, 2008 well, if there is lisp out there to explode an assembly of solids, it is doubtful it will run as you've drawn - since the lisp won't know about what a cabinet is, the sides of the middle cabinet will 'explode' into each side of the end cabinets. Thats why I only explode one cabinet at a time. What software are you using for your cabinets? IM NOT LOOKING TO EXPLODE A SERIES OF CABS. THAT IS JUST THE DRAWING I WAS GIVEN TO POST UP. IF YOU KNOW OF A SUCH A LISP TO EXPLODE SOLIDS, CAN YOU DIRECT ME TO IT. IT DOES NOT HAVE TO BE PERFECT I CAN MODIFY IT MORE. JUST NEED SOMETHING TO GET ME STARTED. Quote Link to comment Share on other sites More sharing options...
Marty Evans Posted April 16, 2009 Share Posted April 16, 2009 I could also use something like this, there was one that I used a long time ago called 3d burst Marty Quote Link to comment Share on other sites More sharing options...
