Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: VBA and XML
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    230
    Default VBA and XML
    I would like to write data in an xml file and later read the needed data from this file. Is this possible with VBA for AutoCad and can someone give me a short example (I'd like to write in an xml file handles and centerpoints of all the circles in the drawing, as well as Handles, StartPoints and EndPoints of all the lines in the drawing)
    Any help will be highly appreciated!
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Thanks God, I'm far enough from Hitleropa
    1,697
    This should get you started this way, I hope
    Code:
    Option Explicit
    Public Const strFilePath As String = "C:\TestXML.xml"
    Public Sub WriteLinesToXML()
    ' request reference to library:
    ' Microsoft XML.
        Dim objDoc As MSXML.DOMDocument
        Dim objNode As MSXML.IXMLDOMNode
        Dim objRoot As MSXML.IXMLDOMElement
        Dim objSub As MSXML.IXMLDOMElement
        Dim objColl As Collection
        Dim i As Integer
        Set objColl = GetLinesData
        Set objDoc = New DOMDocument
        objDoc.resolveExternals = True
        Set objNode = objDoc.createProcessingInstruction( _
                      "xml", "version='1.0' encoding='UTF-8'")
        Set objNode = objDoc.insertBefore(objNode, _
                                          objDoc.childNodes.Item(0))
        Set objRoot = objDoc.createElement("dataroot")
        Set objDoc.documentElement = objRoot
        objRoot.setAttribute "xmlns:od", _
                             "urn:schemas-microsoft-com:officedata"
        For i = 1 To objColl.Count
            Set objSub = objDoc.createElement("Line")
            objRoot.appendChild objSub
            Set objNode = objDoc.createElement("Handle")
            objNode.Text = objColl.Item(i)(0)
            objSub.appendChild objNode
            Set objNode = objDoc.createElement("StartPoint")
            objNode.Text = objColl.Item(i)(1)
            Set objNode = objDoc.createElement("EndPoint")
            objNode.Text = objColl.Item(i)(2)
        Next i
        objDoc.Save strFilePath
    End Sub
    Private Function GetLinesData() As Collection
        Dim oSset As AcadSelectionSet
        Dim oEnt As AcadEntity
        Dim oLine As AcadLine
        Dim ftype(0) As Integer
        Dim fvalue(0) As Variant
        Dim dxfCode, dxfValue
        Dim varStp As Variant
        Dim varEnd As Variant
        Dim tmp(0 To 2) As String
        Set objColl = New Collection
        With ThisDrawing.SelectionSets
            While .Count > 0
                .Item(0).Delete
            Wend
            Set oSset = .Add("$Lines$")
        End With
        ftype(0) = 0: fvalue(0) = "LINE"
        dxfCode = ftype: dxfValue = fvalue
        oSset.SelectOnScreen dxfCode, dxfValue
        For Each oEnt In oSset
            Set oLine = oEnt
            tmp(0) = oEnt.Handle
            varStp = oLine.StartPoint
            varEnd = oLine.EndPoint
            tmp(1) = CStr(Round(varStp(0), 3)) & "," & CStr(Round(varStp(1), 3)) & "," & CStr(Round(varStp(2), 3))
            tmp(2) = CStr(Round(varEnd(0), 3)) & "," & CStr(Round(varEnd(1), 3)) & "," & CStr(Round(varEnd(2), 3))
            objColl.Add tmp
        Next oEnt
        Set GetLinesData = objColl
    End Function
    ~'J'~
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    230
    Fixo, this works fine!!! Thanks!
    And how can I from another sub open this XML document and get the data for a line with handle "17E"?
    Do you know where I can read more abot XML foundamental for VBA? I think it might be very helpful to me...
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Hi Joro,
    I don't know a good links about XML
    and in fact I'm working with it just
    sporadically
    You can retrive the desired data by
    readind file as simple text file and then
    to strip unused chars, perhaps with
    Regular expression to find the particular
    string
    Search Google btw
    Of course. I'll let you know if I can
    to find something about
    ~'J'~
  5. #5
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Quote Originally Posted by Joro-- View Post
    I wrote this code too quickly so maybe
    some mistakes here, not tested extensively
    Let's try
    Code:
    Private Function FindHandle(strFileName As String, strHandle As String) As Variant
    Dim objNodeHdl As MSXML.IXMLDOMNode
    Dim objNodeSpt As MSXML.IXMLDOMNode
    Dim objNodeEpt As MSXML.IXMLDOMNode
    Dim outArr(0 To 2)
    Dim bln As Boolean
        Dim xmlDoc As MSXML.DOMDocument
        Set xmlDoc = New DOMDocument
        bln = xmlDoc.Load(strFileName)
            For Each objNode In xmlDoc.childNodes(1).selectNodes("Line")
              Set objNodeHdl = objNode.childNodes.Item(0)
              If StrComp(objNodeHdl.Text, strHandle, vbTextCompare) = 0 Then
              Set objNodeSpt = objNode.childNodes.Item(1)
              Set objNodeEpt = objNode.childNodes.Item(2)
              outArr(0) = objNodeHdl.Text
              outArr(1) = objNodeSpt.Text
              outArr(2) = objNodeEpt.Text
              Exit For
              End If
            Next objNode
        Set xmlDoc = Nothing
    FindHandle = outArr
    End Function
    'usage:
    Sub HandleTest()
    Dim ar
    Dim fn As String
    Dim hdl As String
    fn = "c:\TestXML.xml"   '<--change file name here
    hdl = "17E"   '<-- change Handle here
    ar = FindHandle(fn, hdl)
    MsgBox "Handle: " &  ar(0) & vbcr & _
               "Start point: " &  ar(1) & vbcr & _
               "End point: " &  ar(2)
    End Sub
    ~'J'~
    Last edited by fixo; 25th Jun 2008 at 02:06 pm. Reason: missed ending line of code
  6. #6
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    230
    I tried it but there is a problem with the line
    Code:
    For Each objNode In xmlDoc.childNodes (1).selectNodes("Line")
  7. #7
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Code:
    Worked just fine here, I don't know
    why it's not working for you
    ~'J'~
  8. #8
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    230
    It says:
    Run-time error '91'
    Object variable or With block not set
    and the respective line is selected by the de******...
  9. #9
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    230
    Fixo, sorry, it was my fault...
    I played a little bit with the first code, so I made it cut the initial lines of the xml file about the version and encoding. So now I changed the line to
    Code:
    For Each objNode In xmlDoc.childNodes(0).selectNodes("Line")
    and it's OK
    THANKS AGAIN!
  10. #10
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Hi, Joro
    Please, upload here your final code,
    perhaps, it will helps to somebody else
    Glad, you solved it
    Cheers
    ~'J'~
