Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
  1. #11
    Full Member
    AutoCAD 2012
    Jul 2009
    Poughkeepsie, NY
    36
    Try this..
    Code:
    (defun spline-to-pline (/ i)
      (vl-load-com)
      (setq *thisdrawing* (vla-get-activedocument
       (vlax-get-acad-object)
            ) ;_ end of vla-get-activedocument
     *modelspace*  (vla-get-ModelSpace *thisdrawing*)
      ) ;_ end of setq
      (setq spline-list (get-spline))
      (setq i (- 1))
      (if spline-list
          (setq msg "\nNumber of segments <100>: ")
          (initget 6)
          (setq num (getint msg))
          (if (or (= num 100) (= num nil))
     (setq num 100)
          ) ;_ end of if
          (repeat (length spline-list)
     (setq splobj (nth (setq i (1+ i)) spline-list))
     (convert-spline splobj num)
          ) ;_ end of repeat
        ) ;_ end of progn
      ) ;_ end of if
    ) ;_ end of spline-to-pline
    (defun get-spline (/ spl-list obj spline no-ent i)
      (setq spl-list nil
     obj  nil
     spline  "AcDbSpline"
     selsets  (vla-get-selectionsets *thisdrawing*)
     ss1  (vlax-make-variant "ss1")
      ) ;_ end of setq
      (if (= (vla-get-count selsets) 0)
        (setq ssobj (vla-add selsets ss1))
      ) ;_ end of if
      (vla-clear ssobj)
      (setq no-ent 1)
      (while no-ent
        (prompt "\nSelect splines: ")
        (vla-Selectonscreen ssobj)
        (if (> (vla-get-count ssobj) 0)
     (setq no-ent nil)
     (setq i (- 1))
     (repeat (vla-get-count ssobj)
       (setq
         obj (vla-item ssobj
         (vlax-make-variant (setq i (1+ i)))
      ) ;_ end of vla-item
       ) ;_ end of setq
       (cond
         ((= (vlax-get-property obj "ObjectName") spline)
          (setq spl-list
          (append spl-list (list obj))
          ) ;_ end of setq
       ) ;_ end-of cond
     ) ;_ end of repeat
          ) ;_ end of progn
          (prompt "\nNo entities selected, try again.")
        ) ;_ end of if
        (if (and (= nil no-ent) (= nil spl-list))
     (setq no-ent 1)
     (prompt "\nNo splines selected.")
     (quit)
          ) ;_ end of progn
        ) ;_ end of if
      ) ;_ end of while
      (vla-delete (vla-item selsets 0))
      spl-list
    ) ;_ end of get-spline
    (defun convert-spline (splobj n / i)
      (setq point-list   nil
     2Dpoint-list nil
     z-list      nil
     spl-lyr      (vlax-get-property splobj 'Layer)
     startSpline  (vlax-curve-getStartParam splobj)
     endSpline    (vlax-curve-getEndParam splobj)
     i      (- 1)
      ) ;_ end of setq
      (repeat (+ n 1)
        (setq i (1+ i))
        (setq p (vlax-curve-getPointAtParam
           splobj
           (* i
       (/ (- endspline startspline) n)
           ) ;_ end of *
         ) ;_ end of vlax-curve-getPointAtParam
        ) ;_ end of setq
        (setq 2Dp        (list (car p) (cadr p))
       2Dpoint-list (append 2Dpoint-list 2Dp)
       point-list   (append point-list p)
       z        (caddr p)
       z-list       (append z-list (list z))
        ) ;_ end of setq
      ) ;_ end of repeat
      (setq summ (apply '+ z-list))
      (setq arraySpace
      (vlax-make-safearray
        vlax-vbdouble ; element type
        (cons 0
       (- (length point-list) 1)
        ) ; array dimension
      ) ;_ end of vlax-make-safearray
      ) ;_ end of setq
      (setq vert-array (vlax-safearray-fill arraySpace point-list))
      (vlax-make-variant vert-array)
      (if (and (= :vlax-true (vlax-get-property splobj 'IsPLanar))
        (= summ 0.0)
          ) ;_ end of and
        (setq plobj (add-polyline
        2Dpoint-list
        vla-AddLightweightPolyline
      ) ;_ end of add-polyline
        ) ;_ end of setq
        point-list
        vla-Add3DPoly
        ) ;_ end of setq
      ) ;_ end of if
      (vlax-put-property plobj 'Layer spl-lyr)
      (vla-delete splobj)
      (vlax-release-object splobj)
    ) ;_ end of convert-spline
    (defun add-polyline (pt-list poly-func)
      (setq arraySpace
        vlax-vbdouble
        (cons 0
       (- (length pt-list) 1)
        ) ; array dimension
      ) ;_ end of setq
      (setq vertex-array
      (vlax-safearray-fill arraySpace pt-list)
      ) ;_ end of setq
      (vlax-make-variant vertex-array)
      (setq plobj (poly-func
      *modelspace*
      vertex-array
           ) ;_ end of poly-func
      ) ;_ end of setq
    (defun c:s2p ()
      (spline-to-pline)
    ) ;_ end of c:s2p
    (prompt
      "SPLINE-TO-PLINE by Tony Hotchkiss. Enter S2P to start"
    ) ;_ end of prompt
  2. #12
    Forum Newbie
    McWaters12's Computer Details
    Windows XP SP 3
    Toshiba Satellite
    1.86 Ghz
    2 GB
    80GB
    500 GB
    AutoCAD 2011
    Jan 2011
    Auburn, AL
    6
    When I try to convert a 2d polyline to a regular polyline, it then asks me to choose between options like 'open' 'fit' 'close'. I'm not really sure which one to choose. I have been choosing 'open' but then it's like i have to choose it thousands of times. I don't know what is going on.
  3. #13
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    To get out of the pedit you should hit enter or escape.
  4. #14
    Forum Newbie
    Land Desktop 2009
    Dec 2012
    4
    Try using overkill. It worked for me. I learned it from a good friend, a legend in the CAD industry that goes by the name candymountain.
  5. #15
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    shrimp: You're suggesting the use of Overkill to obtain what end result?
  6. #16
    Forum Newbie
    Land Desktop 2009
    Dec 2012
    4
    It will convert 2d polylines to polylines
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Well let's hope the OP did not wait until June 2008 for an answer. But it will prove useful to others with the same question.
    You're in the running for today's prize for the person that resurrects the oldest thread. 4 years 6 months. LoL
  8. #18
    Forum Newbie
    Land Desktop 2009
    Dec 2012
    4
    Haha, yeah I know its old as hell but I did a search on google and couldnt find any answers on it so when I found this thread I joined today to make sure the answer is out there for anyone who may need it in the future.
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Quote Originally Posted by shrimpbiscuits View Post
    OVERKILL doesn't work here to convert 2D Polyline to Polyline.
    CONVERTPOLY works just fine as does PEDIT.
  10. #20
    Forum Newbie
    Land Desktop 2009
    Dec 2012
    4
    Neither one of those worked for me for converting from 2d to a regular poly but overkill did just what I needed for some reason.
  1. convert Spline to Polyline
    By Beadin Sabovic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jun 2013, 04:39 pm
  2. Convert Spline to polyline?
    By MikeP in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th May 2008, 05:06 pm
  3. Convert a spline to polyline
    By JaketheMan in forum AutoCAD General
    Last Post: 7th Aug 2007, 02:00 pm
  4. How do I convert an line to a polyline ?
    By nurquhar in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2005, 02:38 pm
  5. Convert Arc to Polyline
    By cyberfreak in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2005, 11:15 am
