Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 31
  1. #21
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Can you post a .dwg?
  2. #22
    Super Member PotGuy's Avatar
    PotGuy's Computer Details
    Windows 7 Premium
    Structural
    PotGuy's Discipline Details
    Temporary Works
    Structural
    (Trainee) CAD Techie/Draftsman
    Revit 2017
    Oct 2012
    London
    728
    Quote Originally Posted by inevelus View Post
    most importantly, i think we can all agree that splines suck.
    Quote Originally Posted by SEANT View Post
    That does seem to be the prevailing opinion, though I’m not sure why.
    Splines are too unpredictable to my liking. They never go where you're Pline was placed (Point for point) where as Fillet does a good job in both rounding off and not screwing you over!
    Angry rant over.
    This space changes a lot. Normally dependant on mood.
    Smilies are abundant in my posts.
    There's no crying in CAD but there sure is a lot of whining not to mention gnashing of teeth, pulling of hair and cursing - ReMark
    There is no crying in CAD. Only mouse slamming and keyboard smashing - RobDraw
  3. #23
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    I’m reading between the lines of your post; Pardon me if I’ve misinterpreted.
    If the unmodified data is in the form of a straight segment Polyline then a PEDIT – SPLINE does morph as you said. The curve no longer passes through the original vertices. It sounds like you prefer PEDIT – FIT, as it maintains a connection to the original vertex information. The path, however, can meander quite drastically from one vertex to the next.
    There are better interpolation schemes for vertex data. Splines utilize that scheme, but a CAD operator has to use the SPLINE command; specifically the FitPoint variant. Now the resultant curve will pass through the vertex. The scheme is further refined by the various Knot Parameterization options.
    See the attached example.
    The SPLINE command requires more work, but the enhanced interpolation may be worth the effort.
  4. #24
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Splines are used where splines are needed.
    Polylines are used where polylines are needed.
  5. #25
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Quote Originally Posted by JD Mather View Post
    Yes indeed!!
  6. #26
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    That statement seems a bit incomplete. A student may find that it creates more questions than it answers.
    What are some of the determining factors that encourage the use of one entity over the other? If we were to consider intermittent elevation data (as may be pertinent to the resurrector of this thread, given the discipline designation as CIVIL), what would be the most accurate form of contour? Or, more mechanical, a limited budget needs wing cross sections CNC cut based on NACA airfoil data?
  7. #27
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    ...and it should. I just didn't want to leave the previous statement that seemed to indicate there is something wrong with using splines.
    Splines are absolutely necessary where splines are required. I use them all the time (but I use a different Autodesk CAD program most of the time and it doesn't even have polylines).
    Hmmm, what entity type is a Helix in AutoCAD, well List indicates Helix - but it is a spline curve.
  8. #28
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    ...and it should. . . . .
    Ah! I see, then, that we are making similar recommendations, i.e., investigate whether Spline have anything to offer a particular workflow. I think that shift in attitude would benefit many that are more familiar with the “AVOID SPLINES AT ALL COST” mentality.
    . . . . a different Autodesk CAD program most of the time and it doesn't even have polylines . . . .
    That interesting. It’s apparent that Autodesk had devoted additional resources to spline geometry. Based on AutoCAD, though, I wasn’t sure if they were fully committed due to a couple of bugs (rather obscure, fortunately) that had not received attentionin the latest release. It’s nice to see that they take the process seriously.
  9. #29
    Forum Newbie
    AutoCAD 2013
    Dec 2013
    1
    select all 2dpolyline -> explode -> select all line-> join = polyline
  10. #30
    Full Member Debalance's Avatar
    Debalance's Computer Details
    Asus P9X79 LE/C/SI s2011 ATX bulk
    Intel Core i7 3820 (BX80619I73820)
    Kingston DDR3 4x4096Mb PC3-17000 2133Mhz (KHX2133C11D3K4/16GX)
    GIGABYTE Radeon HD7970 OC WINDFORCE (GV-R797TO-3GD)
    Kingston SSDNow V+200 120GB (SVP200S3B7A/120G)
    WD WD1001FALS 1000GB
    See details...
    Debalance's Discipline Details
    See details below.
    C++ and C# programming
    AutoCAD 2010
    Nov 2013
    Moscow, Russia
    75
    Quote Originally Posted by farah View Post
    In my opinion it is too complicated algorithm. Personally, I use TotalPurge utility. It automatically converts any 2DPOLYLINE into LWPOLYLINE.
    SuperBoundary • Superior replacement for the standard BOUNDARY (BPOLY) command
  1. convert Spline to Polyline
    By Beadin Sabovic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Jun 2013, 04:39 pm
  2. Convert Spline to polyline?
    By MikeP in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th May 2008, 05:06 pm
  3. Convert a spline to polyline
    By JaketheMan in forum AutoCAD General
    Last Post: 7th Aug 2007, 02:00 pm
  4. How do I convert an line to a polyline ?
    By nurquhar in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2005, 02:38 pm
  5. Convert Arc to Polyline
    By cyberfreak in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2005, 11:15 am
