Offset and delete source
anothercadguy
Greeting to all,
I am trying to built a lisp to offset a line. here's what I have:
(defun c:off ()
(Command "_offset" "e" "yes" pause)
the only thing with this is that I cannot find the variable where auto stores the original setting and once I exit my custom command, auto cad keeps the "erase" source as yes.
Obviously I am not too familiar with lisp yet, so any help will be greatly appreciated.
thanks in advance.
  • Replies 21
  • 3dwannab
    8
  • anothercadguy
    4
  • alanjt
    3
  • rkmcswain
    2
Please use code tags when posting lisp code. Also, you can disable smilies using the checkbox under "Miscellaneous Options" in each post.
Now to the original problem. I don't think there is a variable that controls the erase option. However, you could use this line to turn off the erase feature
(command "._offset" "_E" "_No" "" "_E")
have a look at this, it's real quick and real dirty.
(defun c:OFF (/ offset_dist obj_2_offset offset_side)
(setvar 'cmdecho 0)
(while (= offset_dist nil)
(setq offset_dist (getdist "\nOffset distance: "))
);while
(while
(while (= obj_2_offset nil)
(setq obj_2_offset (entsel (strcat "\nPick object to offset <" (rtos offset_dist) ">: ")))
);while
(while (= offset_side nil)
(setq offset_side (getpoint "\nSide to offset on: "))
);while
(command "offset" offset_dist obj_2_offset offset_side "")
(command "erase" obj_2_offset "")
(setq obj_2_offset nil)
(setq offset_side nil)
);while
(princ))
Thanks for the code and smiley info rkmcswain. I've tried your method but it wouldn't fly. the alanjt script works but it loops towards the end, Once you enter the distance and offset your line, the commands stays put and won't accept any other distance.
thanks for your reply s
oops, i guess i added too many while
try this:
(setvar 'cmdecho 0)
);while
);while
);while
(princ))
not a problem. if i get a chance this weekend, i'll actually sit down and scratch something a lot better out. i did that real quick last night w/o testing.
  • 9 years later...
try this:
(setvar 'cmdecho 0)
);while
);while
);while
(princ))
Hi Alan,
I tried this with decimal places offset but reverts back to the previous offset used.
I tried offsetting 72.5 and it didn't work. Thanks.
Hi Alan,
Architectural units maybe. Try entering the line
to see if it returns 72.5
Now enter the line
does it prompt "Pick object to offset : " ?
The offset_dist variable is localized so it won't remember your last entry: (/ offset_dist obj_2_offset offset_side)
Here's a simple example that saves a default offset distance:
(defun c:off (/ e off p)
 ;; Get saved offset from registry or default to 1
 (setq	off (atof (cond	((getenv "MyOffsetProgram"))
		("1")
 (if (and ;; Prompt for distance, if nil use default
   (setq off (cond ((getdist (strcat "\nOffset distance <" (vl-princ-to-string off) ">: ")))
		   (off)
   ;; Pick something to offset .. needs more error checking ( ie a block will bonk it )
   (setq e (entsel (strcat "\nPick object to offset: ")))
   ;; Pick a side to offset or use point in entsel
   (setq p (cond ((getpoint "\nSide to offset on: "))
		 ((cadr e))
   (progn ;; Offset object
   (command "_.offset" off (car e) p "")
   ;; Delete original (entdel won't **** the bed if the object is locked)
   (entdel (car e))
          ;; Write our default offset to registry
   (setenv "MyOffsetProgram" (vl-princ-to-string off))
 ;; SSHHHHH!!
(vl-load-com)
Edited by ronjonp
I found the problem to my intial problem. I had done:
(defun c:ODEL nil (c:OFFSET_DELETE))
(defun c:OFFSET_DELETE ( / )
to create two command prompts forgetting about the variables.
Now enter the line
Yes it retruns as expected.
This brings up the question. By deleting that variable but the script won't run with the new value which is the issue I had.
Is there any way for it to remember the entered offset next run?
I tried delcaring that as a global like:
(defun c:OFFSET_DELETE ( offset_dist / offset_dist obj_2_offset offset_side )
But get ; error: too few arguments.
Thanks, guys.
That's cool, thanks. I can sort out the filtering of the pick objects to filter blocks etc.
I tried to get it to work so that I could pick more entities by.
(command "_.offset" off )
(while (/= 0 (getvar 'cmdactive))
	(command (car e) p pause)
	(entdel (car e))
		 ((cadr e))
But was unsuccessful.
Got it working in a loop but just need to remove the user getting asked the offset distance each time.
Here's the code until I work that out :)
(defun c:OFFSET_DELETE (/ e off p)
("1")
(while
	(off)
		((cadr e))
	(while (command "_.offset" off (car e) p ""))
	(entdel (car e))
 ;; SSHHHHH!!
(vl-load-com)
Wrap the Entsel in a While is not "INSERT" else do again assoc 0 is object type, or if you do a dump and look at method supported Offset is one of the methods supported. Bit like "has-attributes" checks if block has attributes. Using method means dont need to add lots of objects checking. Will try to find something.
Command: DUMPIT
Select object: ; IAcadLine: AutoCAD Line Interface
; Methods supported:
;   Offset (1)
(setq ans "N")
(while (/= ans "Y")
(setq obj (vlax-ename->vla-object (car (entsel "\nPick object"))))
(if (= (vlax-method-applicable-p obj "Offset") T)(setq ans  "Y")(alert "Not a object that can be offset\nplease pick again"))
Almost forgot about this, some code I have use it all the time, at any time you like it skips the need to type offset just type Oxxx and it will auto ask to offset an object a distance as define by the numbers following the O, the only quirk is for decimals need - instead of a . period, eg O123 is offset 123 it also does circles and fillet.
Its part of a bigger code set so will cut out and test before posting.
Edited by BIGAL
That's cool.
I've modified that so it doesn't fail if nothing is selected.
(defun c:TEST1 ( / obj )
(while
	(not
		(and
			(setq obj
				(car (entsel "\nSelect Offset-able object:"))
			(= (vlax-method-applicable-p (vlax-ename->vla-object obj) "Offset") T)
			(princ (vlax-method-applicable-p (vlax-ename->vla-object obj) "Offset"))
	(prompt "\nNothing offset-able selected")
(vl-load-com) (princ)
I've only got a chance to look at this today.
Thanks guys for your help.
Here's the working code. Done it quicker than I expected.
; ABOUT
; Offsets by specified distance.
; Distance remembered through different ACAD sessions.
; Original and majority of code done by user ronjonp here: http://www.cadtutor.net/forum/showthread.php?24646-Offset-and-delete-source&p=699122&viewfull=1#post699122
; MY EDITS, BY 3DWANNAB ON 24.03.18
; I've added a loop to pick more objects for offset after the first one is completed.
; and error checking to only select offset-able objects.
; It also doesn't fail if nothings selected.
; USAGE
; 'ODEL' or 'OFFSET_DELETE'.
  ("1")
(while (if (and ;; Prompt for distance, if nil use default
     (off)
 ; (setq e (entsel (strcat "\nPick object to offset: ")))
    (while
       (not
          (and
             (setq e
                (entsel "\nSelect Offset-able object: ")
             (= (vlax-method-applicable-p (vlax-ename->vla-object (car e)) "Offset") T)
    ; (princ (vlax-method-applicable-p (vlax-ename->vla-object (car e)) "Offset"))
    (setq e e)
       (prompt "\nNothing offset-able selected!")
    ((cadr e))
 (entdel (car e))
 ;; SSHHHHH!!
(vl-load-com)
3dwannab,
I guess I don't understand the purpose for this lisp routine correct me if I'm wrong but the offset command that's in AutoCAD already remembers the offset distance until you change it and it also gives you the opportunity to erase the object selected. Am I missing something?
Thanks,
Brian
It deletes the original object. I know there's an option to delete in offset but that's two extra steps. OFFSET>Erase>Yes>Amount as opposed to ODEL>Amount
Plus it was a challenge for me to practice my LISP writing.
